cobassc
dude 4.0beta2 web access under wine
Fri Aug 06, 2010 8:54 am
I have dude 4.0beta2 setup under wine. Everything is working fine apart from the web access. this is the netstat results:
tcp 0 0 *:ssh *:* LISTEN
tcp 0 0 *:2210 *:* LISTEN
tcp 0 0 *:2211 *:* LISTEN
tcp6 0 0 [::]:ssh [::]:* LISTEN
as you can see no web access running on port 80. it is activated in the dude server configuration.
cobassc
Re: dude 4.0beta2 web access under wine
Fri Aug 06, 2010 11:46 am
Please help. I am waiting for the answer to see if i have to format the pc and install windows os because i really want to use the web access for network troubleshooting
cobassc
Tue Aug 10, 2010 9:20 am
ok still no reply on this only views. I guess i will have to format the machine and install windows.
thanks anyway.
jtroybailey
Thu Feb 24, 2011 1:27 pm
Sorry to dig up an old thread but i have just come across the same issue. The Dude 4 Beta 2. I have tried changing the default port. Running under WINE.
lebowski
Thu Feb 24, 2011 4:41 pm
In regular windows the web browser portion is started as another thread. I would bet that the method used to start the web server is not handled correctly.
stepw
Sun Mar 20, 2011 3:34 am
It's actually another process, not thread that web-server starts in. Web-server instance seems to be using named pipes to communicate with the local server instance, which doesn't work well under wine.
I submitted a feature request a while ago to allow web-server instance to communicate via TCP/IP like client instance does. That would also allow having web-server on a host other than server main node.
Users browsing this forum: No registered users and 11 guests
