ctech4285
dude on rb433ah
Wed Sep 08, 2010 3:17 am
ok i installed dude on the RB, but where do i find the config options????
normis
Re: dude on rb433ah
Wed Sep 08, 2010 2:39 pm
connect to the IP address with the Windows Dude program.
ctech4285
Re: dude on rb433ah
Wed Sep 08, 2010 5:49 pm
i get login failure, using the same usr/psw then winbox
do i need to do anything special on the rb to allow remote connection on that port?
stretch
Re: dude on rb433ah
Wed Sep 08, 2010 6:10 pm
Hi, default username for Dude is "admin" and password is blank, even if You have different UN and PW on Your RB.
ctech4285
Re: dude on rb433ah
Wed Sep 08, 2010 10:47 pm
sweet thank you
gmidia
Re: dude on rb433ah
Fri Sep 24, 2010 4:05 pm
i would not recommend dude on rb433 unless you are going to use it solely for the dude monitoring function, it uses resources
Users browsing this forum: No registered users and 21 guests
