xezen
Long time Member
Long time Member
is this possable with the dude or can you add it?
Mon Oct 18, 2010 12:05 pm
i would like to set up diffrent users
admin1
admin2
admin3
admin4
all addmins have diffrent firewalls
so i want to set up te dude server
like this
admin1===logs in via port 3000
admin2===logs in via port 5000
admin3===logs in via port 3100
admin4===logs in via port 5030
admin5===logs in via port 3060
or must i just redirect it with mikroik board via
2210
example
dst x.x.x.x:3000 redirect to dst y.y.y.y:2210
?what the best way to do this
If i dont No Ask someone That Does!
chrisd13
Re: is this possable with the dude or can you add it?
Mon Oct 18, 2010 12:58 pm
Hi Xezen, In the dude you can only listen on one port unless you have multiple agents setup which can then run on a port that you specify for each agent instance, but this would seem to be a bit over the top just to give each admin a port to connect to. Personally I would say that the easier and more managable way would be to do the port redirect via rOS.
Users browsing this forum: No registered users and 13 guests
