ditonet
Forum Veteran
Forum Veteran
Send mail via server which require SMTP authentication
Sun Oct 24, 2010 12:44 am
Here is my small utility to send mail via server which require SMTP authentication.
To configure it to work with your mail acount, run it with command-line parameter 'config, e.g:
dito_asms.exe config
Small window will appear, fields content is self-explanatory
Fill all fields, test and save your settings.
Settings are stored in registry in key 'HKEY_CURRENT_USER\Software\DITO' and they are encrypted using AES-128 algorithm.
To send mail run app with three command-line parameters: 'TO address' 'Subject' 'Mail body', e.g.:
"C:\Program Files\Dude\dito_asms.exe" nobody@nowhere.com "Service [Probe.Name] on [Device.Name] is now [Service.Status]" "([Service.ProblemDescription])"
A parameter that contains spaces must be surrounded by "double quotes".
Tested on Win XP and Win 7, works from Dude :) (thanks to gsandul).
Regards, Grzegorz.
EDIT: the file was removed, there is already a newest version, check my last post
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
condei
Re: Send mail via server which require SMTP authentication
Thu Nov 11, 2010 7:48 pm
Can I use your app to send to several mail accounts? How is that achieved?
I tried to separate mail addresses with commas with no luck
Ivan Conde
chrisd13
Fri Nov 12, 2010 6:31 pm
Maybe setup a distribution group that you can add the email addresses to and then just add that one into the SMTP app. (if multiple addresses can not be put into the field). :)
Don't forget to give Karma if we help you out :)
ditonet
Forum Veteran
Forum Veteran
Sat Nov 13, 2010 1:19 am
Here is new version (1.0.0.15) which support multiple recipients:
dito_asms.zip
Syntax is:
"C:\Program Files\Dude\dito_asms.exe" "nobody@nowhere.com,billg@microsomething.com" "Service [Probe.Name] on [Device.Name] is now [Service.Status]" "([Service.ProblemDescription])"
List of recipients must be surrounded by double quotes, comma is delimiter, no spaces.
Regards, Grzegorz.
Mandrax
Fri Nov 26, 2010 4:41 pm
HI
i'm getting 'test mail failed with error code 0' every time I click on test settings
I'm using Windows 7
Mandrax
Mon Nov 29, 2010 7:50 am
Hi
Cant seem to get this thing up and running.every time if I click on the test settings I get a test mail failed with error code 3 or 0
Can somebody please help me
ditonet
Forum Veteran
Forum Veteran
Mon Nov 29, 2010 11:32 am
This application was tested on Win7 by me and everything was good.
Attached you can find latest version (1.0.0.16) which logs communication with SMTP server during testing to file.
dito_asms.zip
This file named 'dito_asms.log' is located in app directory.
Hope this helps.
Regards, Grzegorz.
Mandrax
Mon Nov 29, 2010 2:01 pm
I did what you said and still no luck
i have attached a screen shot of the settings I'm using and the log file.
Do i need too change something in dude accept for the string I need to put in
Thanx for the help
ditonet
Forum Veteran
Forum Veteran
Mon Nov 29, 2010 2:17 pm
Log file clearly shows that is no response from mail server. Typical log looks like this:
2010-11-29 10:25:05 : 10:25:05 <Send> EHLO NITEWORX
2010-11-29 10:25:05 : 10:25:05 <Recv> 250-0002.srv.abc.pl Hello dwg47.internetdsl.tpnet.pl [82.x.y.z]
250-SIZE 52428800
250-PIPELINING
250-AUTH PLAIN LOGIN
250-STARTTLS
250 HELP
2010-11-29 10:25:05 : 10:25:05 <Send> AUTH LOGIN
2010-11-29 10:25:05 : 10:25:05 <Recv> 334 3JzpomFEqyfi
Maybe this app is blocked by firewall, check this.
Regards, Grzegorz.
Mandrax
Mon Nov 29, 2010 3:28 pm
Hi
Okay it seem that we're getting some where now
I changed the port of gmail to 587 and then the program confirms that the mail have been sent but still nothing in my inbox
see attached for log file
Thanx for the quick reply's
PS. turning of the firewall didn't help much
ditonet
Forum Veteran
Forum Veteran
Mon Nov 29, 2010 3:35 pm
GMail server requires TLS, but this is not supported by this simple app, sorry.
Regards, Grzegorz.
slech
Long time Member
Long time Member
Fri Dec 10, 2010 4:41 pm
sorry for my english
ditonet
Forum Veteran
Forum Veteran
Fri Dec 10, 2010 5:47 pm
Really good idea with 'stunnel'.
Personally I don't use GMail so I'm not able to test this solution.
IMHO if 'blat' works my app also should works, same parameters to set.
For me only one disadvantage of 'blat' is that every mail account parameter is available as plain text, no encryption at all.
Regards, Grzegorz.
jacekarwal
Mon Jun 13, 2011 12:25 pm
Another interesting solution is http://commandlinesendmail.blogspot.com/. Uisng this program you can create such notification :
"c:\Program Files\Dude\senditquiet.exe" -s mymailserwer -port 587 -u mailuser -protocol normal -p mailpassword -f mymailaddress -t toaddress -subject "[Probe.Name] na [Device.Name] [Service.Status]" -body "[Probe.Name] na [Device.Name] [Service.Status]"
Of cource first copy senditquiet to your dude dir.
Regards
Jacek from http://www.arwal.com.pl
Ibersystems
Fri Dec 13, 2013 4:20 pm
Hello, we managed with this problem.
We used Dude with a yahoo account without authentication in 450G boards (example). Yahoo started this week to use authentication. To fix this you have to go to /tool email set starttls=yes
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
jackcheng
Wed Jan 15, 2014 10:37 am
WoW Gold kaufen
Ibersystems
Thu Jan 16, 2014 10:24 am
U need more entries instead of one.
Martín
Users browsing this forum: No registered users and 5 guests
