marcopolo
Email notifications stopped
Wed Nov 24, 2010 1:05 pm
Just noticed all my email notifications have stopped.
First thing I did was restart DUDE
1. Checked the Polling tab on a monitored server which is set 'Use Notifications' = ticked, and the name 'Notification' is ticked, when I check this and press the 'Test' button I get the email.
2. Checked the Server > Services tab and one of the 'type' and the 'Use Noficications' and 'Notification' is unticked.
This seems to have happened all of a sudden, so I'm confused.
marcopolo
Re: Email notifications stopped
Wed Nov 24, 2010 1:54 pm
This seems to have happened since rebooting the server where Dude 3.6 resides
gsandul
Wed Nov 24, 2010 1:59 pm
You should check if notification is enabled on the notifications tab
marcopolo
Thu Nov 25, 2010 12:16 pm
No it isn't, but isn't that showing the setting from the top level in settings > polling if you wanted to set all object to use notifications by default?
If it's unticked you then set at the lower level for each object you want notification for.
My issue was that it was working and then stopped after the server was rebooted, when I then went back into Dude, none of the objects have notifications setup
Freedomwifi
Thu Feb 03, 2011 3:45 am
Did you ever resolve your issue? I am having the same problem but cannot figure out why.
Thanks in advance
ct
marcopolo
Fri Feb 18, 2011 2:31 pm
Yes, it seems that the notifications for each device had become disabled (unticked) so I re-enabled it for the items that have notifications.
Users browsing this forum: No registered users and 7 guests
