bstedh
Create custom oid information table
Thu Nov 25, 2010 5:22 am
I am looking to build an information table similar to the SNMP tab for devices. I have tried using the oid_column command but the data comes in an unusable string. If this data where able to be run vertically instead of horizontally you could actually read the information. :shock:
What I need would be to add custom columns to the snmp tab. I need to see the if_alias of a port so that I know whats pugged in where.
Here are a couple of things I have tried with limited to no success.
I tried this in tool tip but it is unreadable in this format.
[oid_column("1.3.6.1.2.1.31.1.1.1.18")][oid_column("1.3.6.1.2.1.2.2.1.7")][oid_column("1.3.6.1.2.1.2.2.1.8")]
This works but you need to reproduce this for every port manually. This gives me the PORT -- SPEED -- OPER UP/DOWN -- ADMIN UP/DOWN -- PORT ALIAS.
if (string_size(oid("1.3.6.1.2.1.31.1.1.1.1.1")),concatenate (oid("1.3.6.1.2.1.31.1.1.1.1.1")," ",oid("1.3.6.1.2.1.31.1.1.1.15.1")," ",oid("1.3.6.1.2.1.2.2.1.8.1")," ",oid("1.3.6.1.2.1.2.2.1.7.1")," ",oid("1.3.6.1.2.1.31.1.1.1.18.1")),"")
Anybody have any ideas on how to make this information available automatically without having to customize every single device I add or how to create a custom table of information?
gsandul
Re: Create custom oid information table
Thu Nov 25, 2010 11:59 am
If you realy need it, you can do it. In my sample I have 4 functions for 3 interfaces, you will need 25 or 49 function, may be more, depending on interface count on your switch. :)
Note: there is no for or foreach statement in a dude functions.
<?xml version="1.0" ?>
<dude version="4.0beta2">
 <Function>
  <sys-type>57</sys-type>
  <sys-id>11355794</sys-id>
  <sys-name>PortInfo_3</sys-name>
  <code>if (string_size(oid("1.3.6.1.2.1.31.1.1.1.1.3")),concatenate (oid("1.3.6.1.2.1.31.1.1.1.1.3")," ",oid("1.3.6.1.2.1.31.1.1.1.15.3")," ",oid("1.3.6.1.2.1.2.2.1.8.3")," ",oid("1.3.6.1.2.1.2.2.1.7.3")," ",oid("1.3.6.1.2.1.31.1.1.1.18.3"),"\0d\0a"),"")\0d\0a</code>
 </Function>
 <Function>
  <sys-id>11355285</sys-id>
  <sys-name>PortInfo_2</sys-name>
  <code>if (string_size(oid("1.3.6.1.2.1.31.1.1.1.1.2")),concatenate (oid("1.3.6.1.2.1.31.1.1.1.1.2")," ",oid("1.3.6.1.2.1.31.1.1.1.15.2")," ",oid("1.3.6.1.2.1.2.2.1.8.2")," ",oid("1.3.6.1.2.1.2.2.1.7.2")," ",oid("1.3.6.1.2.1.31.1.1.1.18.2"),"\0d\0a"),"")\0d\0a</code>
 </Function>
 <Function>
  <sys-id>11355275</sys-id>
  <sys-name>PortInfo_1</sys-name>
  <code>if (string_size(oid("1.3.6.1.2.1.31.1.1.1.1.1")),concatenate (oid("1.3.6.1.2.1.31.1.1.1.1.1")," ",oid("1.3.6.1.2.1.31.1.1.1.15.1")," ",oid("1.3.6.1.2.1.2.2.1.8.1")," ",oid("1.3.6.1.2.1.2.2.1.7.1")," ",oid("1.3.6.1.2.1.31.1.1.1.18.1"),"\0d\0a"),"")\0d\0a</code>
 </Function>
 <Function>
  <sys-id>11355290</sys-id>
  <sys-name>Allports</sys-name>
  <code>concatenate(PortInfo_1(),PortInfo_2(),PortInfo_3())</code>
 </Function>
</dude>
bstedh
Mon Nov 29, 2010 5:18 pm
This is similar to my second attempt but with 48 port switches it just doesn't work on the map. That is why I was hoping to have the information come up in a table similar to the snmp tab for a device. I had the information come up in the tool tip and it worked but for the fact that all non switch equipment would have 48 blank lines in the tool tip. Otherwise you have to manually edit the tool tip for every single switch.
gsandul
Tue Nov 30, 2010 9:33 am
Just must say, that settings for individual device tooltip is not supported by The Dude.
If I did realy needed such a functionality I would extend The Dude by external python QT application, which will be run as custom Tool for The Dude.
So, ask your programmers or write it by yourself.
Users browsing this forum: simintal and 8 guests
