nahuelon
Problem with auto discovery and SNMP
Tue Dec 28, 2010 8:10 pm
Hi, here is my problem. I want to use discovery to add multiple devices to my network map but when I use it with SNMP it discovers a second interface's IP address, wich is the same in every device.
When I use discovery without SNMP in subnet 10.152.4.0/24 it works because it does not find the second interface address. When I use SNMP discovery only adds the first device and then it bypass all the devices (i think their are bypassed because the second interface address 192.168.100.1).
I need to use SNMP because I want to add links and some probes using SNMP OIDs.
Thanks in advance.
gsandul
Re: Problem with auto discovery and SNMP
Wed Dec 29, 2010 9:33 am
Could you please describe the reason to have 192.168.100.1 as secondary IP on every device?
nahuelon
Wed Dec 29, 2010 5:57 pm
The devices are Motorola Cablemodems. In the CATV interface it has the IP in range I want to discover, but in the Ethernet interface it has a factory IP 192.168.100.1 which is found with "SNMP discovery".
The same problem I have with Ubiquity devices which has a WLAN interface with a DHCP IP, and in LAN interface their have a "factory" 192.168.80.1.
I have tried to add the IP in black list but I have the same result (only the first device is added).
I am working on filtering SNMP packet wich have 192.168.100.1 in payload using layer7-filter, but it is a patch solution.
Thank you very much.
bstedh
Mon Jan 03, 2011 8:38 am
I am looking for the same solution. I have proprietary wireless transmitters that do the same thing. I have 3 to 6 transmitters at each site and the DUDE only discovers the first one. I also remember seeing a similar post with the issue with customer side CPE's in the past without a solution.
olorin
Thu Mar 24, 2011 10:01 pm
I also need a solution to this. Trying to auto-discover a /24 of cable modems, and I'm having the same issue. As soon as The Dude discovers 192.168.100.1 on a device, it puts all subsequent MAC addresses it finds in that device and doesn't discover any more unique devices.
Users browsing this forum: No registered users and 5 guests
