mxmxmxmxmx
functin to sum traffic of 2 interfaces
Tue Jan 25, 2011 9:24 pm
is it possible to make chart(i need function first), with sum of traffic of 2 interfaces
a. when both interfaces are on the same RB
b. when interfaces are one different RB?
sergejs
Re: functin to sum traffic of 2 interfaces
Wed Jan 26, 2011 10:22 am
You can have chart with two different sources, that will be displayed on the same graph. But there will not be sum for these graphs.
mxmxmxmxmx
Wed Jan 26, 2011 11:10 am
I've made it this way, i have 2 WAN, and i want to see summary traffic.
gsandul
Wed Jan 26, 2011 11:58 am
1) Create new datasource
The code should be
round(rate(diff32(oid("1.3.6.1.2.1.2.2.1.10.1","5","300","192.168.0.250","Cisco"))*8) +
rate(diff32(oid("1.3.6.1.2.1.2.2.1.10.2","5","300","192.168.0.244","Cisco"))*8))
This code will return sum of bitrate for inbound interface rate on 2 devices with IP 192.168.0.250 (interface index 1) and IP 192.168.0.244 (interface index 2). For more information check functions description in The Dude function tab.
2) Create new datasource for outbound traffic. The code will change to
round(rate(diff32(oid("1.3.6.1.2.1.2.2.1.16.1","5","300","192.168.0.250","Cisco"))*8) +
rate(diff32(oid("1.3.6.1.2.1.2.2.1.16.2","5","300","192.168.0.244","Cisco"))*8))
3) Put new created datasources on chart.
4) Enjoy. :D
mxmxmxmxmx
Wed Jan 26, 2011 9:43 pm
well, thanks, almost ok, i've got question about units, where i'm wrong:
oid("1.3.6.1.2.1.2.2.1.16.1") - Bytes
diff32(oid("1.3.6.1.2.1.2.2.1.16.1")) - difference in Bytes
diff32(oid("1.3.6.1.2.1.2.2.1.16.1"))*8 - difference in bits
rate(diff32(oid("1.3.6.1.2.1.2.2.1.16.1"))*8) - rate in bit/s
I thought, that last line should be equal to built in function: bitrate of this intercafe(bit/s), but my result is still 8 or 10 times smaller, where's mistake?
gsandul
Thu Jan 27, 2011 12:17 pm
where's mistake?
Not any mistake.
Take a look at this
concatenate("Rate is: ",round(rate(diff32(oid("1.3.6.1.2.1.2.2.1.10.1"))*8))," ;Bitrate is: ",bitrate(round(rate(diff32(oid("1.3.6.1.2.1.2.2.1.10.1"))*8))))
Bitrate is doing exatly what it should "formats number as bitrate". But on a chart you should put "raw" values.
mxmxmxmxmx
Thu Jan 27, 2011 3:59 pm
You were very helpfull again, thanks, it was my mistake i was looking on upload:
when i need download:
Now it's OK thx.
pnajm
Sat Apr 27, 2019 1:23 pm
Hello, can you please provide code for the sum of 2 interfaces on the same router?
chechito
Wed Feb 19, 2020 8:12 pm
useful topic
thanks for the info
i used to graph queue tree
Users browsing this forum: No registered users and 11 guests
