aymale03
cpu_mem_disk parse failed
Fri Mar 04, 2011 7:30 am
Hi folks
I have this error in cpu_mem_disk funtion and device performance as well: Parse failed
I copied and pasted the original code of these funtions from a new Dude, so I though it could be the solution, but the error is kept.
Could someone help me?
Alejo
lebowski
Re: cpu_mem_disk parse failed
Mon Mar 07, 2011 5:30 pm
Parse failed is usually a missing " or ) out of place, which probe exactly or can you post a screen shot of your probe so we can see?
111111
Tue Mar 15, 2011 1:18 pm
same problem
dude 4.0beta3
even on host where dude is installed falls on there's probes
for a week there is more then 1000 false probes in mail report
In God We Trust. All other must submit X.509 certificate!
lebowski
Re: cpu_mem_disk parse failed - Normis please respond...
Tue Mar 15, 2011 9:05 pm
I am getting more false positives as well. Although I usually get more false positives when I do not set the service to "real time" as soon as the server reboots. There was a patch that forced my server to reboot, so I need to reboot again and set the service to real time. This is just a work around that reduces false positives in w2k sp3 and if I don't set real time I get many more false positives.
My observation is somewhere between Version 3 and 4 something changed and everyone is seeing more false positives. Using automatic export or any disk intensive operations (export backup) can and will cause false positives. So I believe the loop that is doing polling is somehow competing or conflicting with the loop that writes data.
Normis is there any way you guys will take a close look at this?
Thanks,
Lebowski
marioclep
Trainer
Trainer
Fri Mar 16, 2012 7:43 pm
any news for this topic?
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
Users browsing this forum: No registered users and 13 guests
