totalnett
Datasource - Function value
Fri Mar 04, 2011 1:30 pm
have a regular function to get the signal from a device.
oid("1.3.6.1.4.1.119.2.3.69.401.8.1.1.5.1")
This returns a value example like this -50.1
How do i remove the decimal and the . so the value will be -50 ?
I need this to compere the signal with integer value. :)
totalnett
Re: Datasource - Function value
Fri Mar 04, 2011 4:39 pm
Didn't find any way to do this so made a workaround....
Probe -----
Name:
signal check 1
Type:
Function
Available:
if(oid("iso.org.dod.internet.private.enterprises.nec.nec-mib.necProductDepend.radioEquipment.401.8.1.1.5.1")>0,1, -1)
Error:
if(oid("iso.org.dod.internet.private.enterprises.nec.nec-mib.necProductDepend.radioEquipment.401.8.1.1.5.1")*10>-700, "", "Signal under -70")
Value:
Unit:
This will give notification if signal go below -70 db :D
blackpaw
Fri Apr 01, 2011 5:16 pm
heyo
If you go in the Dude to menu "functions" and read the descriptions a bit you can find some that are useful, like:
- round
then your function will be:
round(oid("1.3.6.1.4.1.119.2.3.69.401.8.1.1.5.1"))
success
Andreas
life is one of the hardest
Users browsing this forum: No registered users and 10 guests
