blackpaw
how to create a probe without graphing when discovered?
Wed Apr 06, 2011 1:52 pm
Hi!
When I run a "discover" on a device and it finds a new service, it adds it to the "services" and also starts graphing this service.
Now, for some services I just want them polled but not graphed.
I can put the services in the "ignored" list in 'device type' - but this will remove the service after discovery - I want to keep them.
If I leave the "Value" and "Unit" field empty it still appears in the Services list.
Anyone got an idea how I can create a probe that does not graph by default or what I am doing wrong?
thanks,
Andreas
Dude 4.0 beta 3
life is one of the hardest
gsandul
Re: how to create a probe without graphing when discovered?
Wed Apr 06, 2011 2:24 pm
Hello.
blackpaw
Wed Apr 06, 2011 2:44 pm
Gsandul,
this is the easy solution but I am looking for the complex one ;)
I was looking for a way to create a probe that does not graph from the beginning - I am running a "auto discover" every 24 hours and new services are added if interfaces come up, etc.
My interfaces never need to be graphed, I am graphing bandwidth via the links (on the map)
Also I would just be graphing a 1 (up) or a 2 (down) so this is not neccessary.
Otherwise I just check once in a while and disable graphing in bulk.
thanks
Andreas
gsandul
Wed Apr 06, 2011 3:21 pm
Will this work for you?
Or some services should be graphed and some - not?
If so, create 2 scan shedules, one with disabled authograph services and the other whit enabled authograph services :)
I do not beleive you can do it with probes
blackpaw
Wed Apr 06, 2011 3:44 pm
hmmmmm.....
I admit, enabling a few (CPU/RAM/Temp/etc.) is much less work than disabling a lot :)
Will follow that way. Thanks!!!
Andreas
Users browsing this forum: No registered users and 16 guests
