The installation of Dude (latest beta version and previous stable version) fails during reboot.
The following messages appear in the log after startup on the routerboard 450G verified dude-4.0beta3-mipsbe.npk
installation of dude-4.0beta3-mipsbe.npk failed. could not create dude/lib/libresolv.so.0: File exists
(Note: equivalent messages appear when installing the stable package, with only the name of the files changed)
problem is the same with the original factory installed O/S, and installing 5.0 and 5.1 did not change the problem
after a restart:
The package does not appear in the list of packages, so it can not be uninstalled
The installation file does not get removed from files menu
Restarting the hardware with the software reset (shorting the pc board lands) does reset the configuraiton, but does not eliminate the problem
Is there a way to delete the problem files? Can i access the /dude/lib direftory? Is there another workaround?
thanks in advance.
