mikrotikuser1
use oid in dude
Thu Dec 22, 2011 7:28 pm
i find some oid for use in dude but i cant know how to use them :(
for example: OID .1.3.6.1.2.1.1.3.0 is for router uptime
but i cant use it manually.......
i can use snmp walk or insert oid in label,but i want to use it manually because some oid there isnt in snmp walk and Should set it manually.
normis
Re: use oid in dude
Fri Dec 23, 2011 1:56 pm
how do you want to use it? what do you want to do with this data? place in label?
mikrotikuser1
Re: use oid in dude
Sat Dec 24, 2011 12:10 am
its my Question;
how i use oid?
for example: i used Signal Strength for wireless with this oid in label:
""oid("iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrWireless.mtxrWlRtabTable.mtxrWlRtabEntry.mtxrWlRtabStrength.0.12.66.73.77.101.2")] ""
that it was in "insert oid" in "label".but i want use a oid that there isnt in "inser oid", like this=.1.3.6.1.2.1.1.3.0
so i cant use it in "label"
how i use it?
marioclep
Trainer
Trainer
Re: use oid in dude
Tue Dec 27, 2011 3:42 pm
in label:
variable=[oid("oid.number.value")]
Ing. Mario D. Clep
CTO - MKE Solutions
MikroTik Certified Trainer
mikrotikuser1
Re: use oid in dude
Tue Dec 27, 2011 10:05 pm
like this?
variable=[oid("oid.1.3.6.1.4.1.890.1.5.13.5.11.3.3.1.2d.value")]
marioclep
Trainer
Trainer
Re: use oid in dude
Wed Dec 28, 2011 3:27 pm
like this?
Like this: variable=[oid("oid.1.3.6.1.4.1.890.1.5.13.5.11.3.3.1")]
Ing. Mario D. Clep
CTO - MKE Solutions
mikrotikuser1
Re: use oid in dude
Thu Dec 29, 2011 3:29 pm
not work :(
are you sure work for all OIDs?
lebowski
Re: use oid in dude
Mon Jan 09, 2012 4:57 pm
Here is a very simple probe that will let you know if the uptime is less than 2 days. I made it to alert me when ever a device reboots. You can simply modify it to use any other way.
This can be used to get an email when uptime is below a specified value.
iso.org.dod.internet.mgmt.mib-2.system.sysUpTime.sysUpTimeInstance
This can be placed on the appearance to give you a label.
time:[oid("iso.org.dod.internet.mgmt.mib-2.system.sysUpTime.sysUpTimeInstance")]
If these do not work your SNMP settings are wrong or your device does not support SNMP.
HTH
Lebowski
mikrotikuser1
Re: use oid in dude
Thu Jan 12, 2012 12:59 pm
HTH
Lebowski
yes that's right,but uptime OID there is in dude
i want to add oid that there isn't in dude
for example i want add zyxle dslam temp OId...................
lebowski
Re: use oid in dude
Thu Jan 12, 2012 7:21 pm
Try the following... Right click on the device in question, select snmpwalk, find the interesting OID, right click the oid and select copy and place it into the probe or label of your design. You can use the number notation i.e. 1.3.6.2.5.67.435.x.x.x.
Otherwise I completely misunderstood you...
GL,
Lebowski
Users browsing this forum: No registered users and 13 guests
