Duduhandelman
Appeareance execute function.
Tue Jan 24, 2012 5:55 pm
Hi All,
I'm currently using dude 4 beta 3 and it's rocks :D .
After spending a few hours trying o display batch file output value under the device appearance I decided to write this post.
Does anyone able to succeed in displaying execute function of any exe/batch file under device appreance?
I'm allways getting -1 value which means it was unable to run the file.
All tips are welcome. I'm using double \\ and the syntax looks correct.
Many Thnaks.
Duduhandelman
Re: Appeareance execute function.
Tue Jan 24, 2012 9:12 pm
UPDATE!
On other system its working as it should be.
Both machines running the same OS.
I will update if I will find something.
lebowski
Tue Jan 24, 2012 10:42 pm
I notice that .cmd files didn't seem to work, if you can use bat I am sure I had one working before although I have not kept it since I didn't have a use. I had this on a label for testing... [execute("test.bat",1,"c:\\")]. Which you probably already found by searching.
Duduhandelman
Wed Jan 25, 2012 8:30 pm
Thank you.
I found the problem it's a bug in version 4 beta3.
In 3.5 it's working.
The strange part that it's working after upgrade as well.
So all I needed to do is install 3.5 and upgrade to 4.
Many thanks
Users browsing this forum: No registered users and 19 guests
