MUM Europe 2020
fabio0373
DUDE SMS ALERT
Fri Mar 16, 2012 1:45 pm
Hello everybody,
is there a way to send SMS alert with dude?
Thanks a lot
ste
Re: DUDE SMS ALERT
Fri Mar 16, 2012 2:32 pm
We use gnokii with an attached USB-UMTS Stick.
Works fine.
fabio0373
Re: DUDE SMS ALERT
Fri Mar 16, 2012 2:50 pm
Thank you. I'll try that. There is a dude version of Android?
ste
Re: DUDE SMS ALERT
Fri Mar 16, 2012 2:56 pm
I would like to have one, too ;-))
fabio0373
Re: DUDE SMS ALERT
Fri Mar 16, 2012 3:17 pm
:D....
voip4life
Re: DUDE SMS ALERT
Sat May 12, 2012 2:02 am
I just created an email alert called "SMS" and then set the email address to my_number@tmomail.net (thats the tmobile format anyway, other carriers would be different). Works fine.
samij76
Re: DUDE SMS ALERT
Wed Aug 29, 2012 4:03 pm
What if your internet connection is down? Your alerts wont go anywhere...
I have been looking for solution that i fit in one shell. ( One computer that has dude + sms capable gsm modem)
Optimal system would be winxp or win7 OS with some software for SMS sending and huawei 3G card. that 3G software is for some reason dificult to find.
_Sami
geoffsmith31
Re: DUDE SMS ALERT
Tue Sep 04, 2012 1:34 pm
We have a dial-up modem attached to our Dude server and use SMS-it (Command line SMS application for windows). We have a script that The Dude runs which sends the SMS using the PSTN line. Old-school but it has saved the day when our internet connection is down or we have a problem with our Email system.
fabio0373
Re: DUDE SMS ALERT
Wed Sep 05, 2012 1:22 pm
maybe you can send me the script? :D
Thanks!
geoffsmith31
Re: DUDE SMS ALERT
Sun Sep 09, 2012 9:27 am
I am certainly happy to share it with you. Let me know where to send it as an email. It is quite large and complex as it does more than just send an SMS. It is the main alerting script that we use. In summary: it will send either an email or SMS to the group responsible for a particular service during working hours. After hours it will check the on-call roster and send email or SMS to the on-call person.
You most probably will not want to use it as it is but you are welcome to modify it for your own purposes.
wwalkerii
Re: DUDE SMS ALERT
Sun Sep 09, 2012 12:15 pm
Wouldn't mind having a copy too if you don't mind! :)
Sent from my SPH-L710 using Tapatalk 2
fabio0373
Re: DUDE SMS ALERT
Sun Sep 09, 2012 3:13 pm
geoffsmith31, here's my email: info@flyadsl.it
Thanks a lot
geoffsmith31
Re: DUDE SMS ALERT
Tue Sep 11, 2012 11:30 am
I have sent the info by email to the address you specified.
fabio0373
Re: DUDE SMS ALERT
Tue Sep 11, 2012 11:58 am
You're very kindly :D
I'll keep you informed.
Thank you very much
a212silver
Re: DUDE SMS ALERT
Fri Oct 12, 2012 11:11 pm
Please send script to a212silver@yahoo.com. Much apprciated!
leofab70
Re: DUDE SMS ALERT
Sun Oct 14, 2012 8:33 pm
Hello, I am looking for a solution like this, so please if possible send it to my e-mail leofab70@gmail.com.I appreciate your help
jalokim
Re: DUDE SMS ALERT
Thu Oct 18, 2012 11:22 am
Guys - and how about running url in case of error in dude? I have my own sms gateway and i can send sms from it by pulling url .... is there any way to do this in dude - for ex run webbrowser and close it? Or any other way?
M.
EMOziko
Re: DUDE SMS ALERT
Sat Nov 03, 2012 12:47 pm
M.
Yes I have a such situation too. I just need to make http GET request on alert. But i don't know how :(
We want new versions of The Dude!!!!!!!
ditonet
Forum Veteran
Forum Veteran
Re: DUDE SMS ALERT
Sat Nov 03, 2012 3:07 pm
Try to execute 'wget' (http://www.gnu.org/software/wget/) with SMS Gateway's URL as parameter.
Create notification with type 'execute on server' and command: Full path to wget with URL parameter.
HTH,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
EMOziko
Re: DUDE SMS ALERT
Sat Nov 03, 2012 3:48 pm
HTH,
Yes this solution works when dude installed on windows, but when dude is on routeros, there is no wget or curl :(
ditonet
Forum Veteran
Forum Veteran
Re: DUDE SMS ALERT
Sat Nov 03, 2012 4:26 pm
That's right...
Regards,
gsolmosi
Re: DUDE SMS ALERT
Thu Nov 08, 2012 4:16 pm
Is possible to provide the script? I was set to run dude sms notification but I've no idea about scripting. Thank you a lot.
geoffsmith31
Re: DUDE SMS ALERT
Fri Nov 09, 2012 10:21 am
The script and associated supporting files are too large and complex to post here. Let me know your email address and I will send you the information.
tatianab
Re: DUDE SMS ALERT
Wed Dec 05, 2012 5:31 pm
Please could you send the script to tatianabecerra85@hotmail.com.. Thanks!
geoffsmith31
Re: DUDE SMS ALERT
Sun Dec 09, 2012 8:32 am
I have had a few requests for this script and have now posted it on Google Drive: https://docs.google.com/folder/d/0B8nO4 ... lQNjQ/edit It is shared to the public.
Users browsing this forum: No registered users and 7 guests
