thedoc
ros_command different responce 4.x 5.x print count-only
Sun Apr 01, 2012 10:58 pm
I use this function in dude to monitor the number of firewall connections on a hotspot.
ros_command("ip firewall connection print count-only")
With the upgrade from ros 4 to ros 5 i do see that there is more coming back then only numbers.
Behind the number there are two extra characters. ( cr lf maybe ?)
Should i make some extra scripting filter to remove the two characters ?.
Can i use some extra options from the ros_command to prevent this problem ?
greek
Re: ros_command different responce 4.x 5.x print count-only
Fri Jul 20, 2012 7:14 pm
I have the same promlem!
I found i little workaround:
but it works very unstable! This functoin return "timeout" after 2-3 hours working.
How to fix this problem whith "left" symbols on the end of value?
Users browsing this forum: MSN [Bot] and 6 guests
