tevolo
Bandwidth Monitor for Queue Tree
Mon Apr 23, 2012 5:48 pm
I've been trying to setup a chart to monitor bandwidth usage for each Queue Tree we have, and I finally was able to create this by finding the correct OID using SNMPWalk.
Once I added the Data Source for each OID, I noticed the data it was charting was incorrect. Using a Scale of 1, showed the data but it was far too low compared to my interface charts. I then checked the Data Source for an Interface that I'm charting, and noticed it uses a Scale of 8. Once I changed the Scale to 8 for the Queue Tree, the chart data was accurate.
Why is it a scale of 8?
Devil
Re: Bandwidth Monitor for Queue Tree
Thu Apr 26, 2012 1:26 pm
Could it be that those values are in bits and by multiplying them by 8, you're just making them in bytes?
chechito
Wed Feb 19, 2020 8:39 pm
yes that values are in Bytes
actually there is a 64bit additional value available
Users browsing this forum: No registered users and 25 guests
