maxstel
Trainer
Trainer
SNMP problem with 5.17 - Dude 3.6
Wed Jun 06, 2012 3:59 pm
Hi everybody... Is it normal that all devices with 5.17 don't show SNMP information on Dude map? With 5.16 on same devices, no problem...
Massimo Passerini
STEL S.r.l.
Ferrara - Italy
MikroTik Certified Trainer
meshnet
Re: SNMP problem with 5.17 - Dude 3.6
Wed Jun 06, 2012 4:40 pm
Try setting a network range in the addresses for the community.
We had a similar problem with cacti, until I figured out you had to put something in the addresses option.
Richard
jcem
Wed Jun 06, 2012 5:24 pm
I have the same problem with 5.17 on some devices.
Mainly older RB411AR with ufl connectors
I rolled back to 5.11 and then it works fine
RGDS
maxstel
Trainer
Trainer
Wed Jun 06, 2012 5:27 pm
Richard
Yes, it worked!
Thanks!
Massimo Passerini
STEL S.r.l.
Ferrara - Italy
pacman
Tue Jul 31, 2012 9:14 am
nope, does not work with 5.18.
Looks like Mikrotik have well and truly broken snmp (at least as regards the dude) on the later RouterOS - either that or they just don't want to tell us how to use it having made changes! :-)
Loop Scorpio Ltd
providers of rural broadband
Users browsing this forum: No registered users and 12 guests
