ericsooter
Changing Link Appearance
Sun Nov 25, 2012 5:51 pm
Is there a way to change the link appearance symbol? I would like to use a dotted line for wireless links instead of the zig-zag line. I found "Link Apperance" under Settings->Map. But it only seems to allow changing of colors. I don't mind the zig-zag symbol; but if the link stretches out too far on the map, it takes up too much space.
Eric
ohara
Re: Changing Link Appearance
Sun Nov 25, 2012 5:58 pm
Right-click on the link and choose Settings. Then change the link type.
ericsooter
Fri Nov 30, 2012 4:10 pm
I guess I was looking more into changing the "Wireless" link appearance. I hadn't thought about just changing it to point-to-point. Thanks for the information.
Eric
lebowski
Fri Nov 30, 2012 10:10 pm
Yes you can change it to a dotted link, click on the 3 dots select the link types dialog and add your own custom link type...
Users browsing this forum: No registered users and 3 guests
