Cameron
Get current firmware version using SNMP?
Sun Dec 30, 2012 11:29 pm
Is it possible to get the current firmware version of a Routerboard using SNMP?
ohara
Re: Get current firmware version using SNMP?
Sun Dec 30, 2012 11:40 pm
Try: oid("1.3.6.1.4.1.14988.1.1.4.4.0")
ditonet
Forum Veteran
Forum Veteran
Mon Dec 31, 2012 12:32 am
This OID is RouterOS version not firmware (RouterBOOT).
AFAIK,OID for firmware doesn't exist.
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
wifix
Mon Dec 08, 2014 2:17 am
Yes, it is possible.
Try using oid("1.3.6.1.4.1.14988.1.1.7.4.0")
For me is ok.
Thomas
WiFiX.org
Italian Communication Solutions Provider
jarda
Mon Dec 08, 2014 9:17 am
You can get all oids directly from console, just write "print oid" command in the section you are interested in. Or you can snmp walk thru all oids to see if there is anything you can use. No need to ask individually here.
SeanR2222
Sun May 06, 2018 7:15 am
Any of the below will give you back the SW version
.1.3.6.1.4.1.14988.1.1.17.1.1.4.1
.1.3.6.1.2.1.47.1.1.1.1.2.65536
.1.3.6.1.4.1.14988.1.1.4.4.0
Users browsing this forum: No registered users and 11 guests
