nocune
Error "Dude Server Already Running" on Dude 1.0rc1
Thu Mar 02, 2006 7:57 pm
could someone help me with this?
I had Dude 0.92 runnig in a Win 2003 Server Standard and all were OK.
I installed Dude 1.0rc1 and the installation was well, but one time it launches Dude an insistent pop up window appear saying "Dude Server Already Running".
I have uninstalled it and reinstalled and ir continue poping up this window. Not only one window is about a window each 2 seconds.
I look for dude.exe in task manager and I can not find it, so this is the only version I am running.
Someone has this problem? it's only me?
Greeting in advance,
NOC-UNE
chrisd13
Thu Mar 02, 2006 8:31 pm
Have a look to see if you also have the dudes.exe and dudew.exe processes running, I think the dudes.exe process might be the one causing you problems... I will be installing the rc1 release in the next day or two so will see if this happens for me also.
nocune
Thu Mar 02, 2006 8:58 pm
Thanks for the answer, but dudes.exe is not in the task manager. I did a fresh install uninstalling so dudes.exe and dude.exe were not in the system when I reinstall.
Another thing I see is that while all this popups appears I can interact with the menus and the server button is not green, but still poping. If I stop the server the popup stops but the dude too.
I hope this will have a solution.
Greetings
Denis Basta
Fri Mar 03, 2006 1:55 pm
Looks like this problem persists in multi-user enviroment...
bing
Fri Mar 03, 2006 2:36 pm
I have the same problem, and with every msgbox popup "Dude server is already running", I get new dudes.exe process in my task manager.
When I close Dude, and all the popups, I still have one dudes.exe process left. When I kill him too, and start Dude, I get the same popups non stop. :)
Ivan
normis
Fri Mar 03, 2006 2:37 pm
we will do extensive testing of this, thank you
gustkiller
Sat Mar 04, 2006 4:59 am
i had the same problem here but to fix it i just leave the dude as system service and closed the dude client , them i can access it from any other host on my network, but if i start the dude cliente in his own host its start to tell the same window that shows "the dude server is already running"
in sum , the problem is just when u run the client in the same machine as the server is runing.
Users browsing this forum: No registered users and 5 guests
