termito
Dude-3.6.npk on a cheapest MikroTik Hardware e.g. RB250GS
Sat Apr 13, 2013 7:10 pm
I use The DUDE three years on PC. PC costs many power so I will migrate to a MikroTik hardware.
Can I use The DUDE on
1. MIKROTIK Routerboard RB250GS
2. MIKROTIK Routerboard RB750GL
3. MikroTik RouterBOARD 750
or other cheap solution?
ohara
Odp: Dude-3.6.npk on a cheapest MikroTik Hardware e.g. RB25
Sat Apr 13, 2013 9:49 pm
#2 and #3 you can. Bear in mind that these devices have limited storage space. You will be able to monitor a small network only.
termito
Re: Dude-3.6.npk on a cheapest MikroTik Hardware e.g. RB250
Sat Apr 13, 2013 11:18 pm
Thanks, I have only 50 PC to control with the dude is this ok with MIKROTIK Routerboard RB750GL?
ohara
Sat Apr 13, 2013 11:42 pm
It depends on how you set your probe intervals and how much historical data you want to keep. I just noticed that 750GL doesn't have a USB port, so you will quickly run out of disk space.
I suggest you to look for Atom motherboards with integrated CPU if you are power consumption conscious. Such PC's have a TDP below 20W, http://ark.intel.com/products/family/29 ... or/desktop.
Personally I prefer to run Dude from a SSD drive to render the charts immediately whenever I want them.
termito
Sun Apr 14, 2013 12:22 am
Hmmm,....... Dell OptiPlex FX160 http://www.dell.com/de/unternehmen/p/optiplex-fx160/pd has a Intel Atom 230 1,6 Ghz, perhaps I will buy this
ohara
Sun Apr 14, 2013 12:50 am
It looks cool.
termito
Sun Apr 14, 2013 11:26 am
Today I bought Dell OptiPlex FX160 by ebay for 60 EUR, I will use Windows 7 32 BIT and Install The DUDE and hMailServer http://www.hmailserver.com/
termito
Tue Jun 11, 2013 10:21 pm
Here is my new The DUDE Server on OptiPlex FX160 http://anduro.objectis.net/hardware/del ... ex-fx160-n
Users browsing this forum: No registered users and 11 guests
