MUM Europe 2020
marcos86
Automonitoring
Fri Jun 14, 2013 11:21 am
Hi Everyone,
We've got intalled The Dude in a Windows Server 2003. Sometimes it has a conflict with McAfee and CPU arrive at 100% of use.
I would like to know how could we monitor de CPU of the server in order to know when it is more than 80% of use.
Do we need to install a Dude agent? Do we need to activate any Windows function?
If I try to autodiscover the machine, these are the service that appear automatically:
[img]Probes.png[/img]
Thank you so much for your help in advance,
Marcos.
tomaskir
Trainer
Trainer
Re: Automonitoring
Fri Jun 14, 2013 1:29 pm
Monitor with SNMP and use the CPU probe.
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
marcos86
Re: Automonitoring
Fri Jun 14, 2013 2:57 pm
I tried but always down...:(
lebowski
Re: Automonitoring
Fri Jun 14, 2013 4:16 pm
Can you snmp walk the box if not then snmp is not setup right?
n21roadie
Re: Automonitoring
Fri Jun 14, 2013 4:39 pm
Which profile is better V1-public or V2-public and on router snmp Trap version 1 , 2 or 3 ?
N21roadie,
Network 100% MT for Now?
lebowski
Re: Automonitoring
Mon Jun 17, 2013 6:34 pm
You create your own snmp Community, "public" is a generic community.
Please google "how to enable SNMP" winXP or your flavor of windows.
Lebowski
lebowski
Re: Automonitoring
Tue Jun 18, 2013 12:12 am
Hey thanks for the karma, be careful with SNMP you can auto discover your network and it could cause high router CPU utilization since the dude tries to automatically add services to discovered devices. I think the biggest issue is when you auto discover a router with a huge number of routes, like a BGP connected router or a router with a weak CPU.
marcos86
Re: Automonitoring
Tue Jun 18, 2013 1:35 pm
Ok Lebowski, thank you so much.
My main problem know is try to solve an incopatibility between Dude and McAfee antivirus. If the antivirus starts scanning Dude gets the 100% of CPU. My chief gave me until friday to solve this issue or I will have to uninstall my favorite monitoring tool :( :shock:
tomaskir
Trainer
Trainer
Re: Automonitoring
Tue Jun 18, 2013 3:23 pm
Simply exclude the Dude folder from being scanned?
marcos86
Re: Automonitoring
Wed Jun 19, 2013 1:02 pm
Tomaskir, that's what I'm going to try. I will let you know after the test.
In the other hand, the SNMP is working perfectly know!
lebowski
Re: Automonitoring
Wed Jun 19, 2013 4:30 pm
marcos86
Re: Automonitoring
Thu Jun 20, 2013 3:07 pm
Post subject: Re: Automonitoring Reply with quote
http://www.youtube.com/watch?v=bKgf5PaBzyg
Hahahahah! 1.5 Millions of views in one day xDD That guy is so crazy xDDD
Users browsing this forum: No registered users and 3 guests
