Ivoshiee
Lost all settings.
Fri May 12, 2006 10:34 pm
After another reboot of the PC running the Dude it came up with no prior knowledge of devices, maps, ....
I never saw any errors or anything.
Where does the Dude is holding it's data and is it possible to back up it?
chrisd13
Thu May 18, 2006 2:17 pm
The Dude holds its data in a folder called data in the Dude installation folder. The best way is to export to a xml file from within Dude. You should see two disk icons near the toolbar, one is export and the other is import.
Hope that helps.
Users browsing this forum: No registered users and 10 guests
