asf23
API to get info from LTE interface
Sat Sep 12, 2015 8:15 pm
Greetings,
mini-PCIe LTE modem
according to the wiki (http://wiki.mikrotik.com/wiki/API_command_notes):
in the section "CLI commands that are not in API" there is no mention of the CLI command "info".
Does API can handle this command ?
It works in the terminal (for example):
/interface lte info lte1
It works in the script (for example):
#LTE signal levels
/interface lte info lte1 once do={
:log info "RSSI:= $"rssi""
:log info "SINR:= $"sinr" dB"
Unfortunately i can not manage this command ("info") by API.
Of course, i can try to set the global variables for signal levels in the script and then retrieve/parse its by sending API command like this:
"/system/script/environment/print"
But get those variables for monitoring signal levels in the user application in such way... :lol:
Any help will be appreciated.
P.S.: when LTE modem is in 3G network there is no critical signal parameters for UMTS such as RSCP and Ec/Io in UI - wish these parameters will be incluled in some next upgrades. :)
ShyLion
Re: API to get info from LTE interface
Thu Aug 15, 2019 12:41 pm
Any updates on the topic?
I also woul like to get "/interface/lte/info" via API.
ShyLion
Thu Aug 15, 2019 4:27 pm
On device:
/system script
add dont-require-permissions=no name=lteinfo owner=busadmin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
    ":global lteinfo [/interface lte info [find] once as-value]; :global lteinfotime [/system clock print as-value]"
/system scheduler
add interval=1m name=lteinfo_1min on-event=lteinfo
API call:
=.proplist=name,value
?name=lteinfo
?name=lteinfotime
Thankyou very much
Users browsing this forum: Google [Bot] and 6 guests
