snakepitwalt
how to remove a active connections with API PHP?
Tue Nov 24, 2015 11:29 pm
hi, i need remove active connections from PPPOE of a single user from with PHP API
paste a capture screen.
routeros_api.class.php use. my syntax is similar to the following but no found
by terminal I run this command: interface pppoe-server remove <pppoe-14703>
<?php
include('routeros_api.class.php');
$Username="laklfasd";
$Pass="sadasjkdaskljd";
$api_puerto=8728;
$usuario = 'asdjlkasdl';
$ipRouteros = 'asdñaksdl';
//$comando = 'interface pppoe-server remove <pppoe-14703>';
$API = new routeros_api();
$API->debug = true;
if ($API->connect($ipRouteros , $Username , $Pass, $api_puerto)) {
$API->comm("interface pppoe-server remove <pppoe-14703>");
THANKS!!!
mwarren77
Re: how to remove a active connections with API PHP?
Wed Nov 25, 2015 8:56 pm
try something like
$API->write('/interface/pppoe-server/print', false);
$API->write('=.proplist=.id,name');
$ARRAY = $API->read();
foreach($ARRAY as $keys=>$val){
if($ARRAY[$keys]['name'] == '<pppoe-14703>'){
$API->write('/interface/pppoe-server/remove',false);
$API->write('=.id='.$ARRAY[$keys]['.id']);
or
$API->write('=.proplist=.id', false);
$API->write('?name=<pppoe-14703>');
$API->write('=.id='.$ARRAY[0]['.id']);
I would print the output of $ARRAY via print_r($ARRAY) to make sure that is right on the id.
That is one way . you may need to fiddle with the exact pppoe fields but think that will work.
snakepitwalt
Wed Nov 25, 2015 10:27 pm
try something like
or
not found :( :(
returns
'Connection attempt #1 to 10.28.1.2:8728... <<< [6] /login >>> [5/5] bytes read. >>> [5, 39]!done >>> [37/37] bytes read. >>> [37, 1]=ret=2cf454b8e830f77b78d7a9d5b33a73 <<< [6] /login <<< [14] =name=prueba <<< [44] =response=00473cbb0bc842e37c2aae464e44b07d >>> [5/5] bytes read. >>> [5, 1]!done Connected... <<< [42] /interface/pppoe-server/remove=.id=*F2CEFC'
but no delete to PPPO-SERVER
the user is 14703 do not know if you can delete via user.
seriousblack
Sat Jan 02, 2021 5:07 pm
 $client = zero_says
 $wofBIT=$API->comm("/ppp/active/getall",
                    array(
                           ".proplist"=> ".id",
                                 "?name" => $client,
            $API->comm("/ppp/active/remove",
                  array(
                           ".id" => $wofBIT[0][".id"],
:idea:
Users browsing this forum: No registered users and 36 guests
