midenok
Command to create directory?
Fri Dec 04, 2015 2:15 pm
I just don't get it. Isn't there a straight way to create a directory except "shaman dance" that Google suggests?
RouterOS 6.34
normis
Re: Command to create directory?
RouterOS does not have a proper file manager or directory support.
You can use SMB and then make folders from your Windows Explorer
stewartpe
Sat Jan 02, 2016 4:58 am
ftp into the router, then press ? for a list of commands.
mkdir will be most helpful.
jaadu
Sun Jul 21, 2019 5:05 am
Create the folder you want on your desktop and drag it in to 'Files' via winbox.
eworm
Forum Veteran
Forum Veteran
Tue Jul 23, 2019 11:09 pm
No idea why the script creates user, group and whatever. Given you have http-ssl service enabled this should suffice:
/tool fetch https://127.0.0.1/ dst-path=path/to/create/xxx
Alternatively use whatever webserver. It creates a file as well, just remove that:
/file remove path/to/create/xxx
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Fantomas
Wed Jan 13, 2021 1:49 pm
How about using 'dot' in place of 'xxx' like below. This way the website won't be saved as 'xxx' file even if is fetched (adding keep-result=no won't create any directories):
# ----- Create directory tree with /fetch -----
# Take note of the 'dot' (or 'space') in place of 'file name',
# this will prevent the fetched website from actually being saved as a file
# even if fetch is successful
:local path "disk1/complex/directory/tree/."
:do { /tool fetch dst-path=($path) url="https://127.0.0.1/"; } on-error={ :put "Script will continue dispite an error"; }
:local otherpath "disk1/some/other/dir/."
/tool fetch dst-path=($otherpath) url="https://www.google.com/"
eworm
Forum Veteran
Forum Veteran
Wed Jan 20, 2021 3:14 pm
A file name containing just a dot represents the current directory. So you create the directory and try to overwrite it with a file... This results in an error:
  status: failed
failure: cannot open file
With your code you have to catch and ignore the error.
I prefer my clean solution. 😜
Users browsing this forum: No registered users and 28 guests
