Pada
ppp on-up/on-down variables
Fri Jan 08, 2016 2:31 am
I've struggled for quite a bit to get the variables working that is exposed by the ppp on-up and on-down scripts, because
  1. variable names includes dashes: local-address, remote-address, caller-id, called-id
  2. interface variable isn't the interface's name
So after a while I have managed to reconstruct new and useful variables:
:local localAddr
:local remoteAddr
:local callerId
:local calledId
:local interfaceName
:set localAddr $"local-address"
:set remoteAddr $"remote-address"
:set callerId $"caller-id"
:set calledId $"called-id"
:set interfaceName [/interface get $interface name]
:log info "$user (srcIp=$callerId, dstIp=$calledId) connected: was given $remoteAddr IP (GW $localAddr) and assigned to $interfaceName interface"
I hope this example is useful to others.
My idea in the end is to add/remove Firewall Filter rules for a given IPSec client interface, since the interface name changes to unknown after the client disconnected AND because when I make use of the PPP incoming-filter/outgoing-filter and jump to ppp chain from the forward chain, then my ROS 6.33.3 goes into a weird state by removing all my bridge interfaces.
ditonet
Forum Veteran
Forum Veteran
Re: ppp on-up/on-down variables
Fri Jan 15, 2016 7:46 pm
Thanks a lot, it helped me.
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
lavv17
Thu Oct 06, 2016 11:56 am
Thanks, it helped me too.
It can be made shorter by combining declaration and assignment like this:
:local remoteAddr $"remote-address"
spippan
Thu Apr 13, 2017 2:44 pm
:local localAddr
:local remoteAddr
:local callerId
:local calledId
AWESOME! you, my dir sir, saved me a lot of googling.
raiffeisen data center infrastructure and security
...stay curious
davestahr
Thu Nov 23, 2017 1:01 am
Awesome - thank you! I've been using the on-up and on-down things to invoke remote API calls by means of an http request - sorta clunky. This will make things much faster.
ADahi
Fri Dec 08, 2017 2:07 pm
https://wiki.mikrotik.com/wiki/Manual:P ... r_Profiles
Execute script on user login-event. These are available variables that are accessible for the event script:
    user
    local-address
    remote-address
    caller-id
    called-id
    interface
jgraue
Tue Dec 31, 2019 1:04 am
You made my day!!! I was succesfully using $user but struggling with caller-id. Thanks Sr.
Users browsing this forum: No registered users and 22 guests
