parscon
Delete all connection in Firewall-Connections
Wed Jan 13, 2016 11:11 am
Hello to all
I need a Script that can delete all connections in IP--->Firewall--->Connections
I use this below script but it does not remove all .
/ ip firewall connection {:foreach r in=[find] do={remove $r}}
Please help me .
Best Regards
boen_robot
Re: Delete all connection in Firewall-Connections
Wed Jan 13, 2016 1:58 pm
/ip firewall connection remove [find]
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
keithy
Wed Jan 13, 2016 10:28 pm
/ip firewall connection tracking set enabled=no
:delay 5s
/ip firewall connection tracking set enabled=yes
adjust delay depending upon how many or few connections you're trying to clear
HTH
tullaman
Mon Feb 05, 2018 1:18 pm
Hi All,
boen_robot's answer works for me.
The idea about enabling and disabling conn-tracking for a few secs and then re-enabling didn't work - I tried durations of up to a minute. Maybe reducing the standard connection timeout duration to something less that the period for which conn-track gets disabled would work? But as I said boen_robot's answer does the business.
/Tullaman.
pothi
Sat Feb 02, 2019 5:29 am
Thanks @boen_robot .
Your code / answer still works. I had a small but annoying issue upon failover when the existing connections do not switch to the new ISP. Clearing the existing connections using your code solved the issue.
Love breaking things and start over!
yreks
Sat Feb 02, 2019 7:56 am
If there are a lot of connections - about 5600,
then I had to run to clean
/ ip firewall connection remove [find]
5 times.
At first I received a response in the terminal
no such item (4)
Users browsing this forum: No registered users and 25 guests
