You don't need scripts - just use the limit-at feature and priorities to give priority to the Roku.
limit-at is a misleading name - it's really a "minimum guaranteed bandwidth"
So set limit-at = 256k down / 128k up on the other queues, and set it to something like 75% of your total bandwidth on the roku's queue, and you should get the behavior you want... and set the roku's max-limit to something like 90% of the full pipe, and priority = 1,
set priority = 2-8 on other queues, however you want their relative importance to be, where 1 is highest and 8 is lowest.
Thanks for your advise. I have already implemented simple queues and it doesnt seem to give me the desired affect. I have added a screen grab below. My line is a 4meg down 0.5meg up ADSL line. I have set my total queue to 3400k. For the purpose of this test the two queues that I am using are "dik" and "myles desktop"
You can see from the screengrab and the 3 windows in winbox that everything weighs heavily in favour of the "Myles Desktop" queue. However from the download average you can see on the screen "Dik" has more bandwidth. If I stop the download on "dik" the other connection maxes out the bandwidth.
What am I doing wrong with the queue setup here? Ideally I would want "Myles Desktop" to get as much bandwidth it can and leave the "limit-at" available for "Dik"
Hope someone can help. I have spent a lot of time on this and getting nowhere fast!
Link to original image if the below grab is too small to read -
http://i.imgur.com/WHFYnue.png
