jeroenp
[SOLVED] Any repository with standard functions?
Thu May 12, 2016 3:33 pm
Is there any repository with standard functions for Mikrotik RouterOS?
I'm missing really basic stuff and writing them myself takes quite a bit of time.
I've just put these as a gist (please shoot at them) Mikrotik RouterOS padLeftString and padRightString functions
--jeroen
boen_robot
Re: Any repository with standard functions?
Fri May 13, 2016 6:58 pm
Other than the stuff you see with a tab or "?", there's nothing, which you're right, is a bummer.
There is however the API protocol. For anything REALLY advanced, you can connect over from a remote device, via a program written in whatever programming language you're comfortable with.
But yeah, not having built in basics like string replacements, var dumps, and the like is a big PITA.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
jeroenp
Mon May 16, 2016 12:42 am
I'd rather not rely too much on other devices and stick to what RouterOS itself can do.
But thanks for the confirmation.
I will see what I can do to get a repository up. First I need to find a way to sync the script contents on the Mikrotik with local files on my Mac or Windows machine so I can put it into a git repo.
--jeroen
Users browsing this forum: No registered users and 21 guests
