PMTech
Referencing a file stored on a flash disk
Sun May 15, 2016 12:40 pm
I'm trying to reset my HAP AC Lite and then run a configuration script. This works on my 1100AH, 2011 etc. and I place the config file in the root. On the HAP AC Lite I have to put it in the flash directory so it survives the reboot. If I reset the device via Winbox then everything works and I get my new config. If I try it via the command line then I get an error saying
"input does not match any value of run-after-reset"
Is there something that Winbox is doing in the background to reference that file ?
Hopefully the screenshot gives you all you need to see what I'm doing.
TIA :D
fork
Re: Referencing a file stored on a flash disk
Fri Nov 06, 2020 6:04 pm
4 and 1/2 year later: Same problem. Same question.
Solution:
File must have .rsc suffix!
Users browsing this forum: Google [Bot] and 35 guests
