jeroenp
Any way to get the error-string in `on-error=`
Tue May 17, 2016 9:07 am
`boen_robot` came up with this trick:
:local scripts [/system script print detail as-value]
#Create pseudo files (RouterOS can't create empty ones at will)
:foreach script in=$scripts do={
    /file print file=(($script->"name") . ".rsc")
#Wait for the files to be created "for real"
:delay 2s
#Fill the files with the script's contents
    /file set (($script->"name") . ".rsc") contents=($script->"source")
It failed with `failure: new contents too long`.
Now it is possible to sort of `try...catch` A.K.A. `try...except` using `on-error=`, but how to get back the error message is not in the on-error= documentation (the best documentation is actually the Catch run-time errors example as `on-error=` is not part of the `:execute` command, but part of the `:do` command).
Is there a way to get the error message?
When not: Why is that missing and where to put in a feature request?
--jeroen
Wyz4k
Re: Any way to get the error-string in `on-error=`
Fri Jun 29, 2018 3:51 am
Bump.
I too would love to know how to extract the actual error message.
[support@router] > { :put [:resolve www.example.com.m]; :put "lala"
failure: dns name does not exist
In a do: on-error: setup, how can I read the "failure: dns name does not exist" into a variable so that I can report on it?
Users browsing this forum: joegoldman and 31 guests
