hi there,
is there a possible way to insert per script an specific DHCP Option82 circuit-id on an connected dhcp-client?
(the relay function does not work for me because i have an layer2 path to the BNG only)
background:
i wanna identify the user on my "trusted-equipment" (RT-BOX) and wanna terminate him on an BNG solution.
(authentication then will be made per Option82)
would be great if something is possible per script or an similar solution?
thank you!
christian
