indjov
SMS PING ALERT
Fri Jun 03, 2016 10:45 pm
Hello ,
Does anyone have a script that checked ping Down and Up and when is down sending SMS, and where is up to send sms.
I`m using USB modem .
10x in advance
aacable
Re: SMS PING ALERT
Mon Jun 06, 2016 2:36 pm
ping to what? you can use netwatch tool and configure up n down scripts as required. or use separate scripts for more customized control and send sms as required.
Few scripts for your reference.
Script#1, to send alert when WAN goes down.
# WAN 1 Monitor Script for mikrotik by using two internet host
# With optional Email and SMS Alert, modem is attached to local mikrotik in this example
# but i have added kannel sms gateway and gmail option too. Added many variables
# by Syed Jahanzaib
# http://aacable.wordpress.com
# Email : aacable at hotmail dot com
# Script Last Modified : 25-NOV-2015 / 13:00
# Set variables
:local i 0;
:local F 0;
:local date;
:local time;
:global "DSL1netstatus"
:global "dsl1netlastchange"
# Check dsl-1 GATEWAY to be monitored (Currently we are monitoring internet host AROOT DNS)
:global dsl1host1 "4.2.2.1"
:global dsl1host2 "199.7.83.42"
# Number of Ping Count, how many times each host should ping
:local PINGCOUNT "30"
# PING HTRESHOLD, Multiply above value with 2 , so if you have select 5 in above example, then set below $PINGTS to 10
:local PINGTS "60"
# Setting SMS Number for admin
:local cell1 "03333021909"
# Company Name
:local COMPANY "JAHAN.ZAIB"
#If you dont have kannel sms gateway ignore this.
:local KURL "http://KANNEL_IP:13013/cgi-bin/sendsms"
:local KID "kannel"
:local KPASS "kpass"
# SMS Msg format for localy attached modem in mikrotik
:local MSGDOWN "$COMPANY WAN ALERT: DSL-1 is DOWN."
:local MSGUP "$COMPANY WAN INFO: DSL-1 is UP"
# Set USB Port on which usb modme is connected in Mikrotik
:local PORT "usb3"
# SMS Msg format for Kannel SMS gateway
#:local MSGDOWN "$COMPANY+WAN+ALERT:+DSL-1+is+DOWN."
#:local MSGUP "$COMPANY+WAN+INFO:+DSL-1+is+UP"
# Gmail SMTP Address / If you dont want to send email disable these
:global "gmailsmtp"
:set gmailsmtp [:resolve "smtp.gmail.com"];
:local GMAILID "yourid@gmail.com"
:local GMAILPASS "yourpassword"
# Alerts n info m Send to following Support addresses
:local TO1 "aacable @ hotmail . com"
# Email Subject for DOWN Alert
:local SUBDOWN "$[/system clock get date] $[/system clock get time] -- $COMPANY_ALERT: dsl-1 Primary Internet Link DOWN"
# Email Body for DOWN Alert
:local BODYDOWN "-- dsl-1 Primary Internet Link  at $COMPANY DATA CENTER not responding, \n\nPlease check conectivity... \n\n>>>  Script Designed by ***   Syed_Jahanzaib   ****  <<<"
# Email Subject for UP Alert
:local SUBUP "$[/system clock get date] $[/system clock get time] -- $COMPANY_INFO: dsl-1 Primary Internet Link is now UP"
# Email Body for UP Alert
:local BODYUP "-- dsl-1 Primary Internet Link  at $COMPANY DATA CENTER have been restored \n\n>>>  Script Designed by ***   Syed_Jahanzaib   ****  <<<"
########## Start the SCRIPT ###########
########## DONOT EDIT BELOW ###########
# PING each host $PINGCOUNT times
# IF NOT A SINGLE PING SUCCESSFULL THEN CONSIDER LINK DOWN ## ZAIB
:for i from=1 to=$PINGCOUNT do={
if ([/ping $dsl1host1 count=1]=0) do={:set F ($F + 1)}
if ([/ping $dsl1host2 count=1]=0) do={:set F ($F + 1)}
:delay 1;
# If no response (all ping counts fails for both hosts, Time out, then LOG down status and take action
:if (($F=$PINGTS)) do={
:if (($DSL1netstatus="UP")) do={
:set DSL1netstatus "DOWN";
# Also add status in global variables to be used as tracking
:set date [/system clock get date];
:set time [/system clock get time];
:set dsl1netlastchange ($time . " " . $date);
####### FOR DOWN STATUS, CHANGE THE RULES ########
# If the link is down, then LOG info and warning in Mikrotik LOG window [Zaib]
:log error "DSL1  Gateway Not Responding..."
# "Emailing the DOWN status. . . "
#/tool e-mail send to="$TO1" subject="$SUBDOWN" body="$[/system clock get date] $[/system clock get time]:$BODYDOWN" from=$GMAILID password=$GMAILPASS  server=$gmailsmtp start-tls=yes
# Send SMS via KANNEL
#/tool fetch url="$KURL\?username=$KID&password=$KPASSto=$cell1&text=$MSGDOWN"
# Send SMS via Mikrotik attached modem
/tool sms send port=$PORT phone-number=$cell1 message="$MSGDOWN" channel=0
# Disable pppoe-out1 wan1 dialer and try to re-connect one time only
:log error "DISABLING PPPOE-OUT1 WAN DIALER"
/interface pppoe-client disable pppoe-out1
:delay 10
:log warning "ENABLING PPPOE-OUT1 WAN DIALER"
/interface pppoe-client enable pppoe-out1
####### FOR UP STATUS, CHANGE THE RULES ########
# If ping is ok for 1 host as well reply received, then LOG UP and take action as required
} else={:set DSL1netstatus "DOWN";}
} else={
:if (($DSL1netstatus="DOWN")) do={
:set DSL1netstatus "UP";
# If link is UP, then LOG info and warning in Mikrotik LOG window [Zaib]
log warning "DSL1  Gateway RESTORED ..."
# "Emailing the UP status. . . "
#/tool e-mail send to="$TO1" subject="$SUBUP" body="$[/system clock get date] $[/system clock get time] $BODYUP" from=$GMAILID password=$GMAILPASS server=$gmailsmtp start-tls=yes
# Send SMS via KANNEL Gateway
#/tool fetch url="$KURL\?username=$KID&password=$KPASSto=$cell1&text=$MSGUP"
/tool sms send port=$PORT phone-number=$cell1 message="$MSGUP" channel=0
} else={:set DSL1netstatus "UP";}
Scrip#2, to send sms daily including mikrotik health report.
# SENDING SMS TO ADMIN FOR DAILY MORNING INFO
:local date;
:local time;
:local PPP  ([/ppp active print count-only])
:local UPTIME [/system resource get uptime]
:local CPU [/system resource get cpu-load]
:log warning "INFO: Daily info for MIKROTIK  @ $date $time\nActive PPPOE Users = $PPP\nUptime is $UPTIME\nCPU Load = $CPU\nPowered by J."
:log warning "Sending DAILY MORNING ALERT SMS on $cell1 ... by jz"
/tool sms send port=usb3 phone-number=$cell1 message="INFO: Daily info for AA-Johar  @ $date $time\nActive PPPOE Users = $PPP\nUptime = $UPTIME\nCPU Load = $CPU\nPowered by J." channel=0
Script#2, to send reboot alert, when mikrotik reboots. schedule it to run on reboot.
# SENDING SMS TO ADMINS FOR RESTART ALERT
:delay 30s
:log error "Sending RESTART ALERT SMS ... by jz"
/tool sms send port=usb3 phone-number=03xxxxx message="ALERT: Mikrotik Routerboard CCR restarted now."  channel=0
Some other references.
https://aacable.wordpress.com/tag/mikrotik-sms/
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
indjov
Re: SMS PING ALERT
Wed Nov 09, 2016 3:51 pm
Thanks for your reply and sorry for my late answer.
But netwatch send sms after one ping fail, I need to send SMS only if several(3 or 5) pings fails in line.
Did you have some script for this ?
I try this code but did`t work for me
:local result [/ping 192.168.88.1 count=3]
:global status
:if ($result = 3 && $status != true) do={
  /tool sms send message="link up" phone-number=12345
  :set status true
} else={
  :if ($result = 0 && $status != false) do={
    /tool sms send message="link down" phone-number=12345
    :set status false
Thanks in advance
kcavery001
Re: SMS PING ALERT
Tue Feb 23, 2021 9:00 am
# by Syed Jahanzaib
# Set variables
:local i 0;
:local F 0;
:local date;
:local time;
:local PINGTS "60"
# Company Name
:local KID "kannel"
:local PORT "usb3"
:global "gmailsmtp"
:delay 1;
:delay 10
} else={
:local date;
:local time;
:delay 30s
sir waht if ping is only high or/is slow internet connection,how to send sms? thanks in advance
Users browsing this forum: No registered users and 31 guests
