kkgogo
Can't change Global variable with API
Wed Jun 29, 2016 8:21 am
Hi everyone~ I recently try to do some development with APi,and I got a proboem...
I try to use the api to run a  script in the router. It  suppose to switch the global  variable  betwwen “0” and “1”,but it never change.(in the same time,the ":beep "is working)
And it work find If I run the script under telnet or winbox. Can somebody tell me what i have missed ?
Here is the script
:global stat
:if ($stat=1)  do={:set $stat 0} else={:set stat 1}
:beep length=1s
Deantwo
Re: Can't change Global variable with API
Wed Jun 29, 2016 8:31 am
What about
/set
=name=status
=value=1465304159
(assuming the variable already exists)
or
/global
=name=status
=value=1465304159
(if it doesn't)
I wish my FTP was FTL.
Deantwo
Wed Jun 29, 2016 8:33 am
What permissions does the API user have?
What permissions does the script have?
Which user is the owner of the script?
We just talked about this in another thread.
Here: http://forum.mikrotik.com/viewtopic.php?f=9&t=109696
kkgogo
Wed Jun 29, 2016 8:48 am
script owner is the same as the API user,
and the user is  in full group.
Script permissions is all...
andriys
Wed Jun 29, 2016 9:14 am
:if($stat=1)  do={:set $stat 0} else={:set stat 1}
Not sure it is important, but the use of $ sign here looks inconsistent.
kkgogo
Wed Jun 29, 2016 9:36 am
.I miss a "blank" after "if" when I typed the code , The script in my router it have a "blank",so the script is ok.
kkgogo
Wed Jun 29, 2016 9:41 am
What about
/set
=name=status
=value=1465304159
or
/global
=name=status
=value=1465304159
(if it doesn't)
I try the run a script with API and the variable is modify by the script.. not to use api to modify the  variable ...
Deantwo
Wed Jun 29, 2016 9:46 am
The $s are correct, the "if" statment however was missing a space.
This works:
:global stat
:put $stat
Does this mean you got it to work?
EDIT: Guess not.
kkgogo
Wed Jun 29, 2016 9:49 am
The most important thing is I run the script with the same user, telnet is ok,api is not.but the "beep" part is both working.
Deantwo
Wed Jun 29, 2016 9:50 am
I went by the title of your thread when I quoted that, sorry.
So are you even sure that the script is even run?
What is the code you use to run the script?
To run a script in one of my API programs I do the following (C# using this):
public static bool RunScript(string scriptName)
    bool assumption = false;
    MK _mikrotik = new MK(_ip);
    if (_mikrotik.Login(_username, _password))
        string scriptId = null;
        _mikrotik.Send("/system/script/print");
        _mikrotik.Send("=.proplist=.id");
        _mikrotik.Send("?name=" + scriptName);
        _mikrotik.Send(".tag=findscript", true);
        foreach (string h in _mikrotik.Read())
            if (h.StartsWith("!done.tag=findscript"))
                System.Diagnostics.Debug.WriteLine(h + " *** ACK");
            else if (h.StartsWith("!re.tag=findscript"))
                scriptId = h.Substring("!re.tag=findscript=.id=".Length);
            else
                System.Diagnostics.Debug.WriteLine(h);
        if (String.IsNullOrEmpty(scriptId))
            return false;
        assumption = true;
        _mikrotik.Send("/system/script/run");
        _mikrotik.Send("=.id=" + scriptId);
        _mikrotik.Send(".tag=runscript", true);
            if (h.StartsWith("!done.tag=runscript"))
            else
                assumption = false;
    _mikrotik.Close();
    return assumption;
kkgogo
Wed Jun 29, 2016 9:52 am
This works:
:global stat
:put $stat
EDIT: Guess not.
I have try you code, still can change the variables but the "beep" still work.
andriys
Wed Jun 29, 2016 10:23 am
How comes the following statements (with and without $) are both correct?
{:set $stat 0}
{:set stat 1}
kkgogo
Wed Jun 29, 2016 10:40 am
{:set $stat 0}
{:set stat 1}
with $ or not is the same
Deantwo
Wed Jun 29, 2016 10:41 am
{:set $stat 0}
{:set stat 1}
I don't know, but according to the manual and my experience, when you set or define a variable you should not prefix it with a $.
See: http://wiki.mikrotik.com/wiki/Manual:Sc ... #Variables
EDIT: Ooh, wait, you are right.
I though you meant that the last one should have a $ too. I blame my killer headache.
:global stat
:if ($stat=1) do={:set stat 0} else={:set stat 1}
:put $stat
Fixed it, but oddly enough it worked when I pasted it in the console with the $.
And testing it further, it seems to work fine with or without the $.
BartoszP
Wed Jun 29, 2016 10:54 am
Despite "$" problem ... flipping stat from 0 to 1 and from 1 to 0 could be done as:
:set stat (1-$stat)
Remeber to initalize stat to 0 or 1 in the begining
Real admins use real keyboards.
Deantwo
Wed Jun 29, 2016 10:59 am
Ok, Finally got to test it using the API, and I am able to reproduce your issue.
But I have to fiddle a little with users and permissions to test it fully.
Script I am using:
:global stat
    :if ($stat=1) do={
        :set stat 0
        :beep length=1
    } else={
        :set stat 1
        :beep length=2
EDIT: User permissions and script ownership seems to make no difference. The $stat variable's value will not change.
EDIT2: If I delete the global variable, I can also see that it is not even created when the script is run through the API. Permissions and script ownership again doesn't seem to matter.
Deantwo
Wed Jun 29, 2016 11:14 am
Something as simple as:
:global stat "test"
:log warning $stat
:beep
Seem to fail to actually create the global variable.
Almost as if it is treated as a local variable.
This seems to just fail to run:
:set stat "test"
:log warning $stat
:beep
Even if the global variable exist.
So is there some special permissions that aren't allowed through the API? Or why would this be blocked.
kkgogo
Wed Jun 29, 2016 6:57 pm
:global stat "test"
:log warning $stat
:beep
:set stat "test"
:log warning $stat
:beep
Thank you for your testing!
I have done some test too,and I also think it treated that variable as local variable.
Is it a bug ?
colin
Mon Apr 02, 2018 5:39 pm
still have the same problem in ros 6.41.2, hope it will be fixed in the next release.
hsn6
Fri Nov 23, 2018 12:10 pm
A tested dirty fix should be something like this:
[:execute {:global myglobalvar "myglobalvalue"}]
Another way is to set a scheduler with 1s interval and a line for deleting itself.
Users browsing this forum: No registered users and 9 guests
