MUM Europe 2020
valent
script for keeping adls router in shape?
Sun Sep 24, 2006 8:52 pm
Hi, can you please help me.
We have s missbehaveing adsl router in out network, which for some or other reason stops working.
So we need a script which does the following:
ping some external site (http://www.google.com) if 5 pings drop login via telnet to adsl router and issue "reboot" command.
or
every 6 hours login via telnet to adsl router and issue "reboot" command
Thank you.
Eugene
Forum Veteran
Forum Veteran
Mon Sep 25, 2006 3:34 pm
no way to do this in RouterOS.
Tout individu a droit à la vie, à la liberté et à la sûreté de sa personne.
valent
Mon Sep 25, 2006 6:40 pm
Ah, then we will do it form a linux box on the network.
savagedavid
Trainer
Trainer
Tue Sep 26, 2006 10:32 pm
I think it should be possible. Something like:
:local i 0; {:do {:set i ($i + 1)} while (($i < 5) && ([/ping 64.77.90.2 interval=3 count=1]=0)}; :if ($i=5) do={/system telnet... }
That would ping the IP address 5 times and if all 5 pings time out you could issue any arbitary commands.
Eugene
Forum Veteran
Forum Veteran
Wed Sep 27, 2006 12:19 pm
/system telnet works only in interactive mode.
savagedavid
Trainer
Trainer
Wed Sep 27, 2006 8:40 pm
Then indeed it would not work!
Users browsing this forum: MSN [Bot] and 23 guests
