MUM Europe 2020
IntrusDave
DSCP mangle and queue trees
Sat Jul 30, 2016 8:57 pm
More human readable creation of DSCP Mangles and Queue Tree.
Set the wanInterfaceName and uploadBandwidth.
:local wanInterfaceName "wan0"
:local uploadBandwidth 4200k
:local queueName ("DSCP_" . $wanInterfaceName)
:local dscpClass [:toarray "Network Control,Internetwork Control,Critical,Flash Override,Flash,Immedate,Priority,Routine"]
:local dscp 64
:for thisDscp from 63 to 00 do={
    /ip firewall mangle add action=mark-packet chain=postrouting comment=("dscp_" . $thisDscp) \
         disabled=no dscp=$thisDscp new-packet-mark=("dscp_" . $thisDscp) passthrough=no
/queue tree add max-limit=$uploadBandwidth name=$queueName parent=$wanInterfaceName priority=1
:for thisDscp from=0 to=7 do={
	:local subClass ([:pick $dscpClass $thisDscp] . " (" . $wanInterfaceName . ")")
	/queue tree add \
		name=($thisDscp+1 . ". " . $subClass ) parent=$queueName priority=($thisDscp+1) queue=ethernet-default
	:for thisQueue from=0 to=7 do={
		:set dscp ($dscp-1)
		/queue tree add name=($subClass . " (Pri: " . $thisQueue+1 .")") \
		parent=($thisDscp+1 . ". " . $subClass) priority=($thisQueue+1) \
		packet-mark=("dscp_" . $dscp) queue=ethernet-default comment=("dscp_" . $dscp)
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
pe1chl
Re: DSCP mangle and queue trees
Sat Jul 30, 2016 9:23 pm
It may not be a good plan to create 64 mange rules that all have to be processed...
I normally use this trick to directly use the top 3 bits of the DSCP:
/ip firewall mangle
add action=set-priority chain=postrouting comment="From dscp high 3 bits" \
    new-priority=from-dscp-high-3-bits
add action=mark-packet chain=postrouting comment="Priority 0" \
    new-packet-mark=prio0 priority=0
add action=mark-packet chain=postrouting comment="Priority 1" \
    new-packet-mark=prio1 priority=1
add action=mark-packet chain=postrouting comment="Priority 2" \
    new-packet-mark=prio2 priority=2
add action=mark-packet chain=postrouting comment="Priority 3" \
    new-packet-mark=prio3 priority=3
add action=mark-packet chain=postrouting comment="Priority 4" \
    new-packet-mark=prio4 priority=4
add action=mark-packet chain=postrouting comment="Priority 5" \
    new-packet-mark=prio5 priority=5
add action=mark-packet chain=postrouting comment="Priority 6" \
    new-packet-mark=prio6 priority=6
add action=mark-packet chain=postrouting comment="Priority 7" \
    new-packet-mark=prio7 priority=7
IntrusDave
Sat Jul 30, 2016 9:37 pm
I don't think that is a good direction. If you have DSCP compliant hardware and apps, use DSCP. If you have simple hardware, use priorities.
I suppose if you have a low end router, then you can use that. I use the script above on RB2011's and up with 150M WAN's without issue and a CPU load less than 5%
David Joyce
IntrusDave
Sat Jul 30, 2016 9:44 pm
Thanking about it - both ways work. I like the fine-grained control. Most of my routers that really need this are CCR's. I use the same on my home RB3011.
David Joyce
pe1chl
Sat Jul 30, 2016 11:04 pm
I use this on a network to have different priorities for VoIP, normal and background traffic.
We mostly use only 3 DSCP values:
- Expedited Forwarding (2e) for VoIP traffic
- Normal (00) as a default
- Background (08) for background transfers like backups
But we have 8 queues in the queue tree to have some more room for future use
It works very well, VoIP is not affected at all by a backup running over the same link.
It is unfortunate that the queue tree cannot use "priority" value as a selector.   Plain Linux can do it, but RouterOS not.
So the tagging of priority values back to packet marks is required.
mjsabri
Trainer
Trainer
Sat Jul 30, 2016 11:14 pm
i think you Should use HTB for this work
Mikrotik Certified Consultant
[ MTCNA , MTCRE , MTCWE , MTCTCE , MTCUME , MTCINE ]
IntrusDave
Sun Jul 31, 2016 1:20 am
I believe the Queue Tree is HTB.
David Joyce
mjsabri
Trainer
Trainer
Sun Jul 31, 2016 8:27 am
Yes, it is.
frank333
Wed Jan 10, 2018 6:05 pm
beautiful script intrusDave!!!
  • it is correct to use the pppoe-out1 interface in wanInterfaceName when using a pppoeclient ?
  • My ISP gives me a 30megabits download/3megabits upload connection ,it is correct to write 3000k in uploadBandwidth, or the value should be reduced by 10%?
my conf
# jan/09/2018 01:58:09 by RouterOS 6.41
# software id =
# model = RouterBOARD 3011UiAS
# serial number =
add admin-mac=xxxxx auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] bandwidth=30720k/3072k mac-address=\
    xxxxxxxxx name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-LOCOM2
set [ find default-name=ether3 ] name=ether3-TV
set [ find default-name=ether4 ] name=ether4-SERVER
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] name=ether9-ROCKET
set [ find default-name=ether10 ] name=ether10-M900
set [ find default-name=sfp1 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-WAN name=pppoe-out1 \
    password=xxxxx use-peer-dns=yes user=xxxxx
/interface vlan
add interface=bridge name=vlan10 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip dhcp-server option
add code=6 name=dnsantipub1 value="'xxx''xxxxx'"
add code=252 name=autoproxy value="'http://10.0.0.202/wpad.dat'"
/ip dhcp-server option sets
add name=wpad_dnsstop options=autoproxy,dnsantipub1
/ip firewall layer7-protocol
add comment="Siti bloccati" name=sitibloccati regexp="^.+(twitter.com|facebook\
    .com|skype.com|whatsapp.com|messenger.com|hangouts.google.com).*\$"
add name=dhcp ranges=10.0.0.100-10.0.0.254
add name=pool_vlan10 ranges=172.16.10.100-172.16.10.254
add address-pool=dhcp disabled=no interface=bridge lease-time=12h10m name=\
    defconf
Gombeen666
Wed Feb 12, 2020 2:23 pm
I have a few questions and maybe some could comment?
(1) We have PPPoE Vlan's will DSCP or priorities work on that interface
(2) For Mikrotik CPE's that have public IP assigned is "DSCP" a better option
(3) Where CPE does not have public IP but is assigned to TP-link router connected to CPE ether interface is "Priorities" best
Gombeen666
Thu Feb 13, 2020 6:40 pm
I am trying to evaluate the best approach for CPE's and on reading https://wiki.mikrotik.com/wiki/DSCP_based_QoS_with_HTB which is informative, I also think that having 64 mangle rules
is a bit too much, can I ask what is your queue trees
Gombeen666
Sat Feb 15, 2020 4:17 pm
How do I work around bridged VLAN's that carry the PPPoE interface on a CPE ?
Users browsing this forum: MSN [Bot] and 11 guests
