ASRCH
PPPOE connections are connected morning and afternoon disconnect
Fri Sep 23, 2016 8:56 pm
Hi everyone ,
How can I, PPPOE client connections connect and disconnect during certain times ? For example, 7 am to 6 pm connect and at other times are disconnected .
I am a beginner.
rodolfo
Long time Member
Long time Member
Re: PPPOE connections are connected morning and afternoon disconnect
Sat Sep 24, 2016 1:24 pm
Yes
But It depends from the Numbers of client You must disconnct
if al of them or only few, il You authenticate using local user manager or an external radius
rodolfo
IZ0UQV
ASRCH
Sat Sep 24, 2016 6:51 pm
My dear friend
Thank you for your answer.
3 or 4 connections.
Please suggest the easiest way.
I am not familiar with the local user manager and external radius.
Do I need additional hardware and software? (Except MikroTik router).
Please you explain step by step.
pe1chl
Sat Sep 24, 2016 7:03 pm
you could disable the PPPoE server at 7pm and enable it at 7am using the scheduler.
of course it will terminate ALL connections, so this easy solution is not possible when you want to have some connections (e.g. your own) excluded.
Users browsing this forum: No registered users and 10 guests
