MarcFumi
Problems with script
Fri Oct 06, 2006 3:28 pm
Hi, i have a problem when i make this script:
system script add name=ap source="/ip address print
/ip address set [/ip address find interface=ether1] address=192.168.1.155/24"
OS returns this message:
invalid argument name
But if i enter this script manually via winbox this script OK
changeip
Fri Oct 06, 2006 8:53 pm
you can remove the first line, since your using find already ... no need to print in script as its probably hanging it up.
Fumi
Fri Oct 06, 2006 10:25 pm
yeah :D ,it's also giving me error without the print command
:? , i belive that the problem is command find, it doesn't let me use [find] on a script
And if i write
/ip address set 0 address=192.168.1.155/24"
OS accept this sript, but when i run the script not work
any idea?
Thanks,
Marc[/img]
Users browsing this forum: No registered users and 36 guests
