jeroenp
[Mikrotik follow-up needed] Any way to persist a :global variable so it survives reboot?
Thu Oct 13, 2016 4:29 pm
I'm looking for a way to persist a :global variable so it survives a reboot.
Any ideas?
--jeroen
Miracle
Re: Any way to persist a :global variable so it survives reboot?
Thu Oct 13, 2016 5:06 pm
Try store them in "comment"
jeroenp
Thu Oct 13, 2016 6:04 pm
What entity types would best be suited for such a comment?
--jeroen
boen_robot
Thu Oct 13, 2016 8:06 pm
The "/system note" is a good place. It is displayed at the start of every terminal session, but beyond that, it doesn't ever "do" anything. Alternatively, you could create a custom disabled item at any menu, and use it as a comment. By virtue of being disabled, it won't do anything.
OR (my preferred approach), instead of doing that, you could write a startup script in "/system scheduler" that initializes the global variables to whatever values you need.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
jeroenp
Thu Oct 13, 2016 9:20 pm
Thanks. Since it's related to log buffers, I decided to put it in this entry (which I need to bail out on if it doesn't exist anyway):
:put [/system logging action print as-value where name=failedauth ]
The not so cool (or - even though it's a bug - maybe cool), is that WinBox does not allow setting this comment.
--jeroen
jeroenp
Fri Oct 14, 2016 1:22 pm
Woot! You can set and retrieve the comment. But WinBox won't show it or allow you to change it.
Pixie dust!
  /system logging action set failedauth comment=12
  :put [/system logging action print as-value where name=failedauth]
--jeroen
Users browsing this forum: No registered users and 32 guests
