dotis
Print Command
Mon Jan 16, 2017 4:18 pm
Hello there
i want to get in print command only the one column results.
ip interface print , BUT to get only the NAME
or
ip hotspot user print , and AGAIN ONLY the usernames
How is that possible?
Thank you!
PaulsMT
Re: Print Command
Tue Jan 17, 2017 10:17 am
Hello there
or
Thank you!
foreach a in=[/interface find] do={:put [interface get $a name]}
brg3466
Re: Print Command
Thu Feb 04, 2021 7:35 am
I have a similar question it is not print the output in the terminal , but to the array.
Let's say ,
> :global a [/interface print as-value] , and you will get an array with all the interfaces info,
If I just want to get the names of the interface in the array, how to get it ?
the expected result kind of like: a={ ether1;ether2; .. ; wlan1} or a={ {ether1}; {ether2}; ..., {wlan1} }
Thank you !
Jotne
Re: Print Command
Fri Feb 05, 2021 1:35 pm
Not exactly sure what you like to do.
This will get all interface in to array list and then print it:
:local list
 :foreach i in=[find] do={
	:set list ($list,[get $i name])
:put $list
ether1;ether2;ether3;ether4;ether5
I do not think you can use as-value with multi line.
This works
:put ([/system clock print as-value ]->"date")
feb/05/2021
Not OK
:put ([/interface ethernet print as-value ]->"name")
Why do not use Splunk to monitor your MikroTik Router(s)? Look at this page in how to set it up.
MikroTik->Splunk
brg3466
Re: Print Command
Fri Feb 05, 2021 9:50 pm
This is exactly what I want. I tried with "print as-value" but no luck. Looks like it is not possible to "print as-value" for only one properties/field.
Thank you !
Users browsing this forum: No registered users and 25 guests
