rftnon
How To Get Keys of this Array ?
Sun Feb 12, 2017 11:25 pm
How to Get Key entry in associative array?
what about the other way around and remove an entry form an associative array?
how to Get Key the element with value `P` in the code below:
:global rot13 ({});
:set ($rot13->"a") "n"
:set ($rot13->"b") "o"
:set ($rot13->"c") "p"
thanks
BlackVS
Re: How To Get Keys of this Array ?
Mon Feb 13, 2017 5:01 pm
So simple things are still so crazy in RouterOS.
1. First approach is like here - http://www.paperstreetonline.com/catego ... /mikrotik/
2. In the case if known index of element to be removed I prefer use such more simple way (removing element with index $index from array):
:put ([:pick $rot13 0 $index],[:pick $rot13 ($index+1) [:len $rot13]])
I.e. to remove element you construct new array and assign it to the same name:
:set rot13 ([:pick $rot13 0 $index],[:pick $rot13 ($index+1) [:len $rot13]])
Delete by key is much simpler, just write command below to remove element with key "b":
:set ($rot13->"b")
3. It is crazy but :find not works with such arrays. You have to use foreach loop and search index or key manually by checking each element.
Example of iterating through keys/values:
:foreach k,v in=$rot13 do={:put ($k,$v)};
or by index/values:
:for i from=0 to=([:len $rot13]-1) do={:put ($i,[:pick $rot13 $i])};
rftnon
Fri Feb 17, 2017 5:37 pm
Thank you very much dear
Very sorry for being late to respond to health conditions
your answer %100
The problem has been resolved
Thank you very much
devquora
Fri Feb 23, 2018 12:14 pm
The array_keys() function is used to get all the keys or a subset of the keys of an array.
Here is syntax
array_keys(input_array, search_key_value, strict)
CTSsean
Fri May 04, 2018 6:37 pm
Here is syntax
from my testing... this function doesn't exist within RouterOS. Can you give me a syntax example?
rocksy
Thu Feb 20, 2020 2:38 pm
We can get keys of array like that
$array = array( 'one' =>'value', 'two' => 'value2' );
TutorialsMate
Sun Nov 22, 2020 1:17 am
This old thread solved my query too. Thank you everyone.
Users browsing this forum: No registered users and 32 guests
