ramshila27
Command Needed for Hard Reboot of Router OS
Mon Mar 20, 2017 2:08 pm
We are doing the software upgrade and downgrade on Mikrotik Board via script. After upgrade and downgrade I want to hard reboot my router. I know only hard reboot button option. Is there any command which I can run using ssh which will behave just like hard reboot button functionality.
savage
Re: Command Needed for Hard Reboot of Router OS
Mon Mar 20, 2017 5:48 pm
/system reboot?
Regards,
Chris
ramshila27
Tue Apr 11, 2017 8:35 am
This will only reboot the unit.
normis
Tue Apr 11, 2017 9:55 am
How is this different? What would you like to do instead?
dadaniel
Tue Apr 18, 2017 2:40 pm
I think he means such a kernel thing:
echo 1 > /proc/sys/kernel/sysrq
echo b > /proc/sysrq-trigger
normis
Tue Apr 18, 2017 2:41 pm
what good would it to in a RouterOS situation?
p3rad0x
Long time Member
Long time Member
Wed May 03, 2017 5:09 pm
You can buy a slave and call him to plug out the power when you need a hard reboot.
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
Users browsing this forum: No registered users and 5 guests
