Pumpir
Script errors view
Mon Nov 27, 2006 11:02 pm
I am a beginner with scripting in MT, when I am testing some scripts, I have no idea, where to find more information about script result. I have some mistake inside, but when I run a script, Run Count is still 0 and I have no information, where to look for the problem.
Ivan
mneumark
Wed Nov 29, 2006 9:23 am
Have you ran your script and looked in the log to see what it says?
Pumpir
Nothing in log file
Wed Nov 29, 2006 10:41 pm
Sure, I have log window opened to see it permanently, there is nothing.
mneumark
Thu Nov 30, 2006 7:27 am
Can you post your script so we can look at it?
changeip
Thu Nov 30, 2006 8:03 pm
I really hope 3.x has better scripting support. There is absolutely no error output or debugging. You can try putting :log info "line X running" in the script before each command and see where it stops - but sometimes if there is another problem the script won't even run at all.
Sam
Pumpir
Sun Dec 03, 2006 5:49 pm
Finally I found syntax error, but the problem is, that it takes very long time to debug any script when there is no error output.
Giepie
Re: Script errors view
Sat Jun 21, 2008 2:42 am
I agree
It is hard to find bugs in a script with no error output.
I usually hash out newly added portions of my scripts and remove the hashes after everytime the script ran propperly. Once I hashed out something and the script won't run, I have a rough idea for where to look.
It would be very cool if MT Scripting could change the colours of certain elements like in C++ or even MT3.x CLI.
G
The only thing Mikrotik lack, is to send power to your High Sites wirelessly.....
mrz
Wed Jun 25, 2008 1:31 pm
Variables, commands, etc. are in different colors in version 3.x, it is very easy to read script with those colors enabled and find any syntax errors.
When you so /system script print, if script has syntax error it is highlighted in red, so it is very easy to find syntax errors, too.
deweydb
Wed Dec 23, 2020 2:59 am
It would still be very useful to see the syntax error print in the log when the script runs (fails), perhaps with a line number as a bonus.
voskamikfor
Thu Jan 14, 2021 9:18 am
I suggested the following improvements for Mikrotik. They wrote that if there were more demands, they would solve it. So please write to them.
In Winbox script: This would be perfect for anyone who writes scripts. When an error is reported in the terminal window, one has to count where the error row is. Thanks
Image Image
Users browsing this forum: No registered users and 27 guests
