hermeson
PHP API - Add/Remove/Edit PPP user
Tue Aug 08, 2017 6:05 pm
Hi guys, finally I got in to this forum, I have been few weeks saying that I couldn't register.. anyway
Could some help me to find out what I am doing wrong on this code?
/ppp secret set [find name=hermeson] disabled=yes
I tried:
$API->write('/ppp/secret/set '.$user.' =disabled=yes');
then
$API->write('/ppp/secret/set',false);
$API->write($user,false);
$API->write('=disabled=yes');
then
$API->write('='.$user,false);
To add user it is working cool!!! but disable it, nothing.. and soon change profile (edit profile then revome active user)
3 days non-sleeping looking for a code... damn!!!
cheers!!
flysky
Re: PHP API - Add/Remove/Edit PPP user
Wed Aug 09, 2017 9:33 am
try
$arrID=$API->comm("/ppp/secret/getall",
	              array(
		          ".proplist"=> ".id",
		          "?name" => $user,
$API->comm("/ppp/secret/set",
		  array(
			   ".id" => $arrID[0][".id"],
			   "disabled"  => "yes",
hermeson
Wed Aug 09, 2017 2:01 pm
fu.. yeaaahhhh... work perfectly.... man!!! where can I find this kind of language? Mikrotik should let us know this kind of programming language, coz all examples I have found did not work. do u have any manual with those commands?
Thanks a lot!!!!
hermeson
Wed Aug 09, 2017 2:51 pm
As I could understand... the script do not work with user as name, but you always have to find the id then work on the id of client right????
hermeson
Wed Aug 09, 2017 4:55 pm
Hu Flysky,
I tried this
                 array(
                "?name" => $user,
$API->comm("/ppp/active/remove",
        array(
and it didn't work, but instead to active I put secret it does... anything especial to remove the active user??
thanks
hermeson
Wed Aug 09, 2017 5:16 pm
I fouuuuuuuuuuuuuuuuund it LOL
I need to change secret to active when it search for a user....
$arrID=$API->comm("/ppp/active/getall",
                 array(
                "?name" => $user,
        array(
VERYYY COOL!! leave it here for other to learn too!!!
Obrigado
shkelqimkoka
Wed Aug 08, 2018 3:38 pm
guys which php api do you use, can anyone help me with ppp ready script for monitoring/creating/disabling ppp clients ?
seriousblack
Sat Jan 02, 2021 5:02 pm
 $client = zero_says
 $wofBIT=$API->comm("/ppp/active/getall",
                    array(
                                 "?name" => $client,
                  array(
                           ".id" => $wofBIT[0][".id"],
That works for me
:idea:
Users browsing this forum: No registered users and 31 guests
