machack
Some help SMS find and remove
Sat Sep 09, 2017 6:04 pm
Hello
I have a simple script that erases all IMBOX sms, what I would like is to be able to delete only the ones with blank message field.
:foreach i in=[/tool sms inbox find] do={
:put [/tool sms inbox remove $i ]
This is why if we send sms to our customers mikrotik create blank messages into inbox for each one we send.
some help?
Cesar Javier Robles
www.WindNet.com.ar
MTCNA - MTCTCE - MTCRE - MTCWE
ryz
Re: Some help SMS find and remove
Mon Oct 02, 2017 11:17 am
Hi, I have the same problem too.
Sms sent are holded in INBOX dir.
Is it possible to not hold sent messages in INBOX dir ?
andersonid
Sun Dec 17, 2017 8:14 pm
Any updates?
100mux
Sun Aug 12, 2018 1:17 pm
#Delete SMS in Inbox
baronkis
Re: Some help SMS find and remove  [SOLVED]
Sun Apr 07, 2019 7:21 pm
If you need remove only without text messages, you can find message=""
:foreach i in=[/tool sms inbox find message=""] do={
eworm
Tue Apr 16, 2019 12:45 pm
Or without loop:
/ tool sms inbox remove [ find where message="" ];
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
Users browsing this forum: No registered users and 20 guests
