OlegkaOwl
Email if host at netwatch list is down more then 1 day
Wed Nov 08, 2017 12:43 am
Hello!
I need to write a script which informs me by email about the inaccessibility of an every IP-address from the Netwatch list if more than a one day.
I started writing a script, but I do not know how get the parameter "SINCE"
For example;
:local monlist [ /tool netwatch print where status="down" since!="" ]
:foreach i in=$monlist do={
:put (get $i "SINCE");
The result
# HOST TIMEOUT INTERVAL STATUS SINCE
0 192.168.132.20 1s 1m down oct/05/2017 02:36:28
How can i get a date "SINCE" ?
stoser
Re: Email if host at netwatch list is down more then 1 day
Wed Nov 08, 2017 6:36 am
Three possible problems: 1) Instead of the print command, use the find command . 2) since should not be capitalized (SINCE != since). 3) the get command needs to be executed from the netwatch directory level. It does not exist at root level
The following works on a 3011 running 6.40.4. From Terminal, to put the "since" field to the screen, after declaring the local variable i:
foreach i in=[/tool netwatch find where status="up" since!=""] do={:put [/tool netwatch get $i since]}
Kind regards
OlegkaOwl
Wed Nov 08, 2017 7:33 pm
Thank you, it works :)
Users browsing this forum: No registered users and 18 guests
