Squire
Portknock scripting
Fri Dec 15, 2017 5:27 pm
Good day,
So I want to run a script that almost listens(?) for a port knock on the log (yet to be added, if possible)
But I'm having problems getting my find comment then remove to work whats wrong with my script?
:local "address-list" "Knocked-LO"
:local "address-list" "Kick-lo"
:local "Kick-lo" [ /ip  firewall get [/ip firewall address-list find list="Knocked-LO"]]
:if ( [/ip firewall address-list find list=$"Kick-lo" ] = "" ) do={
 [/ip firewall address-list remove [/ip  firewall address-list find list="Knocked-LO"]]
} else={
:log warning "no ones there"
:log warning "kicked all current added IPS"
Squire
Re: Portknock scripting
Mon Dec 18, 2017 9:52 am
So I've got it working however,
how do i get it do nothing when it cant find "kick-lo" ?
:if (
} else={
 [/ip firewall address-list remove [/ip  firewall address-list find list="Kick-lo"]]
kw12157
Thu Dec 28, 2017 1:10 am
Why do you want to almost listen for a port knock?
I have implemented port knocking successfully and love it!
It is all done in the firewall rules, no scripts...
sebastia
Sun Dec 31, 2017 4:36 pm
Would you care to share the details so others could benefit/learn?
kw12157
Sat Jan 13, 2018 6:36 pm
I require 3 knocks to access the router.
Example:
knock1 = 20000
knock2 = 30000
knock4 = 10000
Most port scanners scan from 1 to 65535. That is why I require 2 knocks going up and then 1 knock below them, all within 3 seconds.
This requires 3 Firewall Filter Rules:
1. add action=add-src-to-address-list address-list=Knock1 address-list-timeout=3s \
chain=input comment=Knock1 dst-port=30000 protocol=tcp
2. add action=add-src-to-address-list address-list=Knock2 address-list-timeout=3s \
chain=input comment=Knock2 dst-port=50000 protocol=tcp src-address-list=\
Knock1
3. add action=add-src-to-address-list address-list=Safe address-list-timeout=12h \
chain=input comment="Add to Safe" dst-port=10000 protocol=tcp \
src-address-list=Knock2
Then on your Firewall NAT rules that you want to deny access except after a successful knocking you add src-address-list=safe
Example:
add action=dst-nat chain=dstnat comment="RDP in to .200 with Knock" dst-port=\
3389 in-interface=ether1-WAN protocol=tcp src-address-list=Safe \
to-addresses=192.168.1.200 to-ports=3389
I hope this helps!
Kevin
sebastia
Sun Jan 14, 2018 2:22 am
thx for sharing!
Squire
Sun Apr 22, 2018 3:33 pm
whoops think i gave up on this and forgot i started this thread, anyway
What I want to do is when I port knock, say its called (kick-on-knock) on different ports eg, 1234, when that port has been knocked it want it run a script that deletes any existing established connections with name "Knocked-LO" on the address list then it will expire after say 1 or 2 seconds (1234)
Users browsing this forum: Bing [Bot] and 28 guests
