MUM Europe 2020
horhay
Quickly clone firewall rules via API written in C.
Sun Jan 21, 2018 8:24 pm
I have a need in my work to copy firewall rules from a master router to several dozen other routers. So I wrote this program.
It copies all firewall FILTER, MANGLE and ADDRESS-LIST entries from the hard coded "MASTER" router to the router specified on the command line.
I started with the C API from the wiki by webasdf. I fixed the memory management and added several other routines.
This might be a good example for someone looking to get into programming the API in C.
h0rhay
dcowsill
Re: Quickly clone firewall rules via API written in C.
Tue Jan 23, 2018 3:59 am
Awesome work. That is some well-documented code.
horhay
Fri Jan 26, 2018 6:30 pm
I'm looking for a new project if anyone needs anything written using the API.
boen_robot
Fri Jan 26, 2018 10:43 pm
Have you considered simply making a generic, cross platform, full featured (ideally focused to ease of use for the developer) API client with bindings for various other languages (e.g. for a PHP extension, a Node module, an unmanaged .NET assembly, etc.)?
Current implementations aren't... that... so a new one that is would be awesome.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
horhay
Sat Jan 27, 2018 4:22 am
Sorry. I'm just an old C programmer. Great idea but beyond my abilities. I'm hoping someone needs a program to login to a router and do something. Produce a report or change settings or check something and give a different return value so it can be used in bash scripts. Poll some parameter and dump it to a mysql database.
Users browsing this forum: No registered users and 12 guests
